Old Feb 17, 2013, 05:31 PM
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
Build Log
Foamy Night Flyer ---- X2
Foamy Night Flyer Build Times Two!
The night flying forum has been dead here in what many consider the height of building season. Spring is still several weeks out and it's time to build up the fleet in anticipation of spring. To liven things up a bit this will be a double build. Same airframe, maybe a little different lightings on each.
This will be a 38 inch foamy powered by a Super Tiger .10 and a 3S 1000mah LiPo. The lights will be wired to the balance tap of the battery for easy connection.
First, we cut some depron.
Barn-E-Stormer is offline Find More Posts by Barn-E-Stormer
Old Feb 17, 2013, 05:37 PM
Dark Yet??
Joined Dec 2009
To make a nice rigid foamy I split the wing and elevator down the middle and glue in a piece of 6mm carbon fiber strip.
Old Feb 17, 2013, 05:44 PM
Dark Yet??
Joined Dec 2009
Hinge the ailerons and elevator.
Old Feb 17, 2013, 05:49 PM
Dark Yet??
Joined Dec 2009
Let's get something straight...
And by that I mean our foamy. A plane that is straight and square will fly much better.
This is my foamy assembly table. A slot is cut in the table with a set of alignment holes for the wings and the horizontal stab. It takes the guess work out of making the wing square and centered.
Old Feb 17, 2013, 06:02 PM
Dark Yet??
Joined Dec 2009
Starting with 2 fuselage pieces, split the tabs on the horizontal half and slide it onto the vertical half to form the fuselage. The table slot, a metal straight edge and some triangles keep it straight and square during assembly.
Old Feb 17, 2013, 06:28 PM
Dark Yet??
Joined Dec 2009
The horizontal stab and elevator assembly is now glued to the fuse using the alignment holes in the table.
At this point the LED strip for the "fluorescent tube" is glued down. It will later be covered with a side brace that will glow like a fluorescent light.
Old Feb 17, 2013, 07:21 PM
Dark Yet??
Joined Dec 2009
The ailerons are now hinged onto the wing using Blenderm tape.
Old Feb 17, 2013, 07:24 PM
Dark Yet??
Joined Dec 2009
The wing is now slid into place and aligned using the holes in the table and glued in place.
Old Feb 17, 2013, 07:27 PM
Dark Yet??
Joined Dec 2009
Now the plane is turned over and the filler plate is installed behind the wing. Use a straight edge and square to assure the bottom is true. Glue the wing bottom in place, then the landing gear support gussets.
Old Feb 17, 2013, 07:28 PM
Dark Yet??
Joined Dec 2009
A word on LED strip and connections.
I get my LED strip from two sources Hobby Partz and Hobby King.
The strip from HobbyPartz.com is 6mm wide and has small solder pads. It is lighter, and fits perfectly on the edge of 6mm depron. The down side is...it's harder to solder.
The strip from HobbyKing.com is 9mm wide and has large solder pads. It is a tad heavier, will not work on the edge of 6mm Depron, but is easy to solder.
They have the same number of LEDs per meter and draw the same current, 400ma per meter at 12V.
I strip a old computer parallel cable to get the interconnect wire.
Old Feb 18, 2013, 12:41 PM
Dark Yet??
Joined Dec 2009
I cut my blue LED strip to the lengths for the bottom pattern and tin the pads, then apply the strip to the plane. Trying a new pattern for the bottom. "V"s look good on night flyers and provide great orientation.
Old Feb 18, 2013, 02:11 PM
plcline67's Avatar
United States, WV, Montcalm
Joined Sep 2007
looking good! I may need to get you to build me another one!
plcline67 is offline Find More Posts by plcline67
Old Feb 18, 2013, 04:51 PM
Dark Yet??
Joined Dec 2009
What about your last one? I can repair it or send you some new parts if needed.
Old Feb 18, 2013, 04:55 PM
Dark Yet??
Joined Dec 2009
Tying in the side strips and the bottom of the wing.
Old Feb 18, 2013, 08:36 PM
United States, VA, Blacksburg
Joined Jun 2010
Nice job on this Barn.
Might I post the vid of the SF1 you/we built?
david.merc is offline Find More Posts by david.merc
Sold 36" Wingspan RTF Night Flyer - $115 LPU Only gabrielisrael Aircraft - Electric - Airplanes (FS/W) 1 Feb 13, 2013 07:36 PM
Sold 3d Park Flyer Foamy. rhampton Aircraft - Electric - Airplanes (FS/W) 3 Feb 13, 2013 06:52 AM
Sold 3d park flyer foamy rhampton Aircraft - Electric - Airplanes (FS/W) 0 Feb 11, 2013 09:14 PM
Discussion Scratchbuilt floatie night and or indoor flyers BrownEyedFool Foamies (Scratchbuilt) 9 Feb 05, 2013 08:39 AM
Sold 36" Wingspan RTF Night Flyer - $115 LPU Only gabrielisrael Aircraft - Electric - Airplanes (FS/W) 2 Jan 23, 2013 02:13 PM
