Old Nov 23, 2012, 08:46 PM
THE BUILD IS ON
RPM314's Avatar
United States, NY, Brooklyn
Joined Apr 2012
Idea
Jet design
This is my first EDF design, so I have no experience with this. Does this look airworthy?
It should have a wing loading of about 10oz./sq.ft., so I can lower the wing area if necessary. I plan to use a 64mm fan, 4400Kv on a 3s.
RPM314 is offline Find More Posts by RPM314
Latest blog entry: Falcon Mk.V - Right to the Top
Old Nov 23, 2012, 10:04 PM
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
I think it looks cool and looks totally airworthy. in fact, this very thing has been tried by NASA and JPL with good results. if you've got the size and the wing area, I'd go a little less on Kv (4000) and go up 1 cell to 4S. Dons Wicked sells the best package on the market, hands down. you won't be happy on 3S for very long and you'll be wanting to upgrade anyway. may as well do it from the get go. you'll need at least a 45 Amp ESC for the application. keeping my eyes on this build.
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Nov 23, 2012, 10:34 PM
THE BUILD IS ON
RPM314's Avatar
Joined Apr 2012
I'm a bit budget limited. I was thinking this setup. I only have 3s batteries, so sticking to 3s will save money there.
I forgot to say that this will be 30" span, 320 sq.in. Do you recommend downsizing?
Old Nov 24, 2012, 04:32 AM
Joined Jan 2009
no, you'll be fine at that size.
Old Nov 24, 2012, 07:05 AM
USA
Joined Apr 2007
endless
LOOK'S good prob's i see is space between wing's there's a rule for that wing tip's should have space between them like continous wing thre's a thred on that.
space 1 is offline Find More Posts by space 1
Old Nov 24, 2012, 07:06 AM
USA
Joined Apr 2007
http://www.rcgroups.com/forums/showthread.php?t=1674533
Old Nov 24, 2012, 09:53 AM
THE BUILD IS ON
RPM314's Avatar
Joined Apr 2012
What would happen if the wingtips were joined in a diamond? More drag from interference?
This one appears to work fine.
Old Nov 24, 2012, 04:19 PM
USA
Joined Apr 2007
alpha jet look's good but the 2 wings are so close together they create lift. if you got wings at wrong space its like brick wall top air hits bottom air not allowing air to pass through wing's
Old Nov 24, 2012, 05:40 PM
Joined Jan 2009
best way to do it, is to try it. you won't know if you don't try. the JPL version looked a lot like yours and it worked just fine. how do I know.......................my brother works at JPL. give it a whirl and see what happens.
Old Nov 25, 2012, 10:18 AM
THE BUILD IS ON
RPM314's Avatar
Joined Apr 2012
Alright. If I have to I'll space the wings, but more carbon would be needed if that happened.
A wise man did not once say: "Like everything else in life, cover it with duct tape and hope for the best"
Old Nov 25, 2012, 01:25 PM
THE BUILD IS ON
RPM314's Avatar
Joined Apr 2012
Is the JPL joined wing plane secretive or just lesser known? I can't find any pictures.
Old Nov 25, 2012, 03:01 PM
USA
Joined Apr 2007
me eather. there is a foam edf arf at some hobby co.
Old Nov 25, 2012, 03:17 PM
I don't like your altitude
Stupot46's Avatar
Joined Sep 2011
http://www.nasa.gov/centers/langley/...-tdt-wing.html
There you go
Stuart
Google NASA joined wing,more views and links to other types
Stupot46 is offline Find More Posts by Stupot46
Old Nov 25, 2012, 03:26 PM
USA
Joined Apr 2007
http://aerospaceblog.wordpress.com/2...rsonic-travel/
Old Nov 25, 2012, 07:26 PM
Joined Jan 2009
there's lots of shots and articles on the net. you've just gotta do some searching to find them. you are better to look in NASA articles, since JPL's files are somewhat difficult to locate. I can get access to all this stuff, but I can't give you access to it. LOL.
Discussion ReVolt Jet Design Constructive Input geostomp Electric Ducted Fan Jet Talk 75 Sep 14, 2014 03:32 PM
Video Maiden of a scratchbuild Alpha Jet (Dreamcatcher's design) CrosstownTee Electric Plane Talk 2 Jan 10, 2013 04:49 PM
Discussion New Pusher Jet Design FliegenFrosch Pusher Prop Jet Models 1 Oct 11, 2012 11:11 PM
Help! New Fighter Jet Design Coming Soon! RCJamal Foamies (Scratchbuilt) 30 Oct 11, 2012 10:01 AM
