Old Jul 02, 2014, 02:19 AM
Joined Jul 2004
Jet provost
Hi Dave,
Have you flown the Jetwelt JP?
Reuben
F86_sabre is offline Find More Posts by F86_sabre
Old Jul 02, 2014, 12:59 PM
Joined Dec 2012
Hi Reuben, no I have not quite finished it, nearly there. I flew the smaller 1/6 scale one yesterday for the first time in its finished paint scheme, I really enjoyed the one flight I had, but had to stop due to some contamination in the main fuel tanks. It turned out to be silicon sealant that I used to put the overflow pipes in with so I won't be using that again.
Dave
machine man is offline Find More Posts by machine man
Old Jul 02, 2014, 01:08 PM
Joined Jul 2004
Hello Dave,
Looks cool! Does that have a P80 in which case where did you locate it in the fuse?
Thanks for replying.
Reuben
Old Jul 02, 2014, 01:39 PM
Joined Dec 2012
It will not take a Jetcat 80 due to its size, it can take any turbine in the wren 54 size . I am using a wren 70 which has loads of power for it and it allows the use of con-formal tanks which have been designed for the kit.
Dave
Old Jul 02, 2014, 02:50 PM
Joined Jul 2004
Presumably the fuel tanks are on the CG and the turbine is just behind the tanks...right? Do you have any negative effects with no full intake ducting?
Reuben
Old Jul 02, 2014, 03:38 PM
Joined Dec 2012
The turbine is also on the CG with the tanks around it, the jet pipe is 900 mm long and we have no heat problems or need of ballast. I have done the same mod on the Jetwelt JP moving the turbine as far forward as possible on to the cg.
Dave
Old Jul 02, 2014, 03:42 PM
Joined Jul 2004
Nice setup! Congrats!
Old Jul 07, 2014, 09:21 AM
UK
Joined Nov 2002
Dave
Just in case you were not aware, jet fuel, like petrol, destroys silicon which is why jet models use tygon and not silicon fuel tubing
HarryC is offline Find More Posts by HarryC
Discussion Martin 167 Maryland design and build. RyanPSU21 Scale Kit/Scratch Built 189 Oct 14, 2013 08:29 AM
Found Wanted: PLD-BAC-ESJ; Combo BAC switchjack wdwimbish Aircraft - Sailplanes (FS/W) 1 Sep 06, 2012 03:12 PM
Discussion f-15 build Foam scratch build, wanna go faster Foamies (Scratchbuilt) 60 Sep 04, 2012 12:57 AM
Build Log BaC F-6 Lightning EDF from GAD build mjblack Foamy EDFs 81 Nov 11, 2009 10:10 AM
