Old Oct 01, 2011, 08:55 PM
Joined Jun 2007
Whip antenna
Hello,
Could someone tell me where i can purchase a whip antenna setup for a 72mhz rec?
Also how well do they work? Thanks. Greg
skippyc5 is offline Find More Posts by skippyc5
Old Oct 02, 2011, 07:25 PM
St. Mary, Maryland, United States
Joined Dec 1996
Dreamworks carries them, or at least they used to. With the advent of 2.4 they may not stock em anymore. They work well, only way to get >3Kw EDF's to work reliably on 72 before I switched to 2.4...
Chris True is offline Find More Posts by Chris True
Old Oct 02, 2011, 10:54 PM
DFC~ We Do Flyin' Right
bsbauman's Avatar
USA, GA, Atlanta
Joined Nov 2008
IBCrazy is known for making very nice antennas and have become "standard" for FPV
http://videoaerialsystems.com/produc...tenna-systems/
bsbauman is online now Find More Posts by bsbauman
Latest blog entry: Nice Pic
Old Oct 03, 2011, 09:49 PM
Joined Jun 2007
Thanks for the info. Greg
Old Oct 09, 2011, 08:30 PM
A10pilot's Avatar
United States, TX, Schertz
Joined Mar 2006
Whip Antenna Source
Skippy:
W S Deans company makes the deans connectors as well as the antennas for 72 and 75 MhZ. I used them on some of my gasoline powered plane and they worked just fine. Try the link below.
http://www.wsdeans.com/products/antenna/index.html
When I used them, I used the 2 piece system. You mount the electronics (blue part of the assembly) and the base (threaded portion) in the model and then the antenna screws to the base. Removable antenna makes it easier to transport the model and if it isa scale model, you can remove the antenna for static display
Ed
A10pilot is offline Find More Posts by A10pilot
New Product BluBeam Whip antenna set IBCrazy FPV Talk 19 Sep 19, 2011 11:41 AM
Sold Hitec Electron 6 with Deans whip antenna Vintauri Aircraft - General - Radio Equipment (FS/W) 0 Jun 29, 2011 07:38 PM
Discussion Smiley Antenna with Dean's whip antenna zx1100 Electric Plane Talk 4 Jun 01, 2008 10:31 PM
2-piece whip antenna for 72MHz - also suitable for 35MHz?! Jensst Power Systems 8 Jul 08, 2001 10:59 PM
GWS receiver and a Deans whip antenna mikeb33 Power Systems 8 May 10, 2001 12:44 PM
