Old Jul 07, 2011, 03:03 PM
United States, MA, Medfield
Joined Jul 2010
Two different contact cements stuck like glue
Experiment--
Put water-based Beaon CraftFoam Glue on a piece of FFF (polystyrene foam) and let it dry. (An organic-solvent-based contact cement like Welders or Goop would melt polystyrene).
Put Welders (organic-solvent-based) contact cement on a piece of coroplast (made of polypropylene like EPP) and let it dry.
Stuck them both together.
There ain't no way they're coming apart without tearing the foam to into teeny tiny pieces.
In the past, I tried the Beacon stuff with EPP once with very poor results so I figured I'd never use it again unless I need to use it on polystyrene.
But apparently different types of contact cement are compatible once dried which might be a good trick to know if gluing together dissimilar plastics.
-l2t
learn2turn is offline Find More Posts by learn2turn
Old Jul 07, 2011, 07:12 PM
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Great now i have to go down stairs and start playing with the 30 odd different glues i have down there , not to mention the different materials
Wilfor is offline Find More Posts by Wilfor
Discussion Two Different PK Trojan Models? Martinuk Foamies (Kits) 1 Mar 14, 2011 03:19 PM
Contact cement glue for wetsuits and EPP foam Microbatman Foamies (Kits) 0 Sep 20, 2005 12:13 AM
Yippee! CA Glue Stuck... Help Shiba Beginner Training Area (Aircraft-Electric) 24 Jan 18, 2004 04:10 PM
GWS glue is contact cement? Jar'sbuddy Foamies (Kits) 0 Aug 11, 2002 12:01 PM
Yippee! LiteStik Glue Stuck! Gman Parkflyers 4 Feb 21, 2002 10:17 PM
