Old May 09, 2001, 03:29 PM
racine, wi
Joined Jan 2001
inverted flight
Will a stock ep concept with wood blades eh-83 do inverted sustained flight? These blades seem more semi-symmetrical than symmetrical. I dont want any unpleasant suprises. I know there isnt much reserve.
bpu6999 is offline Find More Posts by bpu6999
Old May 09, 2001, 04:00 PM
19 years on RCG!
United States, NV, Las Vegas
Joined Dec 1996
Nope, she just wont do it. It took a 12 turn RC car motor and symetrical carbon blades for my EP Concept to hover inverted. With the wood blades that are semis and a 16 turn motor, it could loop and roll well, but no sustained inverted. The carbon blades are less than $50 here:
http://www.cyberheli.com
You want MS 395s. Again, I used a 12 turn car motor and 8 cells. The EP Concepts arent really aerobatic at all. If you want great aerobatics, an ECO 8 is the best bet. The new Voyager is a sweet heli, but a little less aerobatic than the ECO....even still, the Voyager I like better! The EP Concept is just an outdated design from over 15 years ago!
Jason
Jason M is offline Find More Posts by Jason M
Old May 09, 2001, 07:15 PM
Matsuyama city, Japan.
Joined Feb 2000
It is possible, if you use a powerful motor and set tight gear ratio. It may be better to modify slightly the front edge of the EH83 areofoil because it may be roughly (plane-like) cut.
However, JRC wood symmetry rotor (25-30USD) is better for inverted flights. In fact, I always use it for 3D acro. It is available at RC shop Asami in Tokyo (Akihabara Town) linked from the link page of http://www.dokidoki.ne.jp/home2/tohrus/ .
Tohru Shimizu is offline Find More Posts by Tohru Shimizu
Old May 10, 2001, 10:54 AM
No "R" !!!!!!!
Fitz Walker's Avatar
United States, TX, Houston
Joined Jan 2000
http://www.fxaeromodels.com/newpage11.htm
-FTZ
Fitz Walker is online now Find More Posts by Fitz Walker
Old May 10, 2001, 11:24 AM
racine, wi
Joined Jan 2001
Thank you gentleman!
I'm really leaning away from expensive/fragile rotor blades though. I had a concept 60 with nice blades - $160 per set - and it flew great. But usually in a crash the blades are the first to go . . .
I'm going to give it a try with the eh-83 blades . . . keep your fingers crossed . . .
By the way - if you had $250 to spend, would you use it to buy a brushless system for the ep or just get a eco-8 with the MM? What is better bang for the buck?
First inverted flight on Duskstick! Scomis Parkflyers 6 Oct 05, 2001 11:36 AM
inverted flight with Zagi 400X stock setup? 177ichael Electric Plane Talk 10 Jun 25, 2001 08:18 PM
Piccolo inverted flight gpeden Electric Heli Talk 3 Jun 25, 2001 01:45 AM
Inverted flight is hard when battery is hanging from plane by esc. Augeredin Electric Plane Talk 7 Jun 21, 2001 10:52 AM
Sky Scooter Inverted Flight! Wade Foamies (Kits) 0 Jun 03, 2001 09:33 PM
