Old Oct 29, 2014, 02:55 AM
Joined Jul 2014
X10 LED blinking
I have a X10 that is blinking its LED once a while but not at any specific intervals. Is this normal or is there something wrong. I use it with a Nano 2 and don't see the Nano blinking.
Also, I saw the comment of binding the Nano with the specific amount of channels already set in the transmitter. Does that apply for the Taranis as well? I did some testing and don't see any difference.
Kid45 is offline Find More Posts by Kid45
Old Oct 29, 2014, 11:48 AM
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
When the LED blinks, it indicates a loss of a single packet of data. This is normal when the transmitter is too close to the receiver. Moving the transmitter away from the receiver should solve this.
You can NEVER change the number of channels being used after binding, no matter which transmitter is used. So, if you add or remove channels from an EVO, Taranis, Graupner, or other transmitters that have this capability, then you MUST rebind the receiver with the new transmitter settings.
JimDrew is offline Find More Posts by JimDrew
Old Oct 29, 2014, 12:01 PM
Joined Jul 2014
So I assume it is only the X10 that will blink, not the Nano, I never saw a Nano doing it. Just for interest sake, why does this happen. This is at about 3 to 4 feet distance between the 2. The Taranis report telemetry lost at about 40 inches.
Old Oct 29, 2014, 01:16 PM
Lake Havasu, AZ
Joined Jun 2005
Correct, the Nano will not blink. If the receiver is too close to the transmitter the RF front-end can become swamped and you will lose packets. If you place the Tx antenna right on the Nano, it can go into failsafe. This is normal with a highly sensitive receiver. It requires 4 times the power to double the effective range. So, if you see a blink at 4 feet away, you would need 400mw (instead of 100mw) to cause the same blinking 8 feet away (double the distance). It would require thousands of watts of power to cause intermittent packet loss in normal flight. You would be dead long before you had a problem flying your plane - you would have been cooked from the inside out.
Old Oct 29, 2014, 01:24 PM
Joined Jul 2014
Thanks.
Old Oct 30, 2014, 10:19 AM
Joined Jul 2014
Now that I think about it, both the Taranis and XPS receivers worked from about 12 inches when I tested both together. It was only the telemetry from the taranis that was lost. Not that it matter, just info.
Discussion DJI iOSD Mini blinking LED? ThisIsFun FPV Equipment 53 Mar 29, 2015 07:03 PM
Discussion Hubsan X4 - blinking LEDs problem piton55 Multirotor Talk 0 Sep 29, 2014 07:16 AM
Discussion Problem aomway 5.8 ghz 1w blinking led foxlfoda FPV Equipment 3 May 19, 2014 02:28 AM
Help! Slow blinking LED on DSM2 satellite Richtofen1916 Radios 19 Feb 27, 2014 05:02 AM
For Sale E-Flite LED NAV Lights: 2 solid green; 2 blinking blue. $15 shipped for all CONUS john-doe Aircraft - Electric - Multirotor (FS/W) 0 Jan 30, 2014 02:53 PM
