Old Mar 14, 2013, 06:04 PM
eatkins's Avatar
Atlanta Metro area GA
Joined Sep 2009
Replacing plug tip for TB6B power Pack
I just bought a Tenergy TB6B charger. The power supply I bought for it does not have the tip to fit into the charger. The charger came with wiring that you can connect to a battery and plug it into the charger so you can charge your batteries at the field.
What I want to do is splice the tip from the field charger wire to the power pack.
What I am not sure of is which wire on the power pack is the + and which is the -.
The pack has two wires coming from it to the tip. Both are black so I cannot tell.
One wire has white writing on it and the other has ridges on it.
Can someone tell me which is Positive and which is Negative?
Eddie
eatkins is offline Find More Posts by eatkins
Old Mar 15, 2013, 07:38 PM
eatkins's Avatar
Joined Sep 2009
bump
Old Mar 15, 2013, 07:50 PM
So. Cal.
Test polarity with a voltmeter, even if someone chimes in and tells you what they think may be the correct polarity.
Incidentally, what is the output voltage and current capacity of the 'power pack'? It may be inadequate for the purpose of powering your charger as any decent power supply should have clearly marked polarity.
Mark
mrforsyth is offline Find More Posts by mrforsyth
Old Mar 16, 2013, 05:05 AM
eatkins's Avatar
Joined Sep 2009
Mark
Hi Mark,
Polarity is clearly marked and listed for the tip. From the tip going back to the charger it has two wires. One has white writing on it and the other has ridges.
Not sure which is (+) and which is (-).
Eddie
Old Mar 18, 2013, 06:37 PM
eatkins's Avatar
Joined Sep 2009
Bump
Old Mar 18, 2013, 06:39 PM
So. Cal.
Do you own a voltmeter or DMM? If not, highly suggest you invest in one.
Here's one for $5: http://www.harborfreight.com/7-funct...ter-92020.html
Many options on eBay as well.
Discussion Current replacement for Medusa Power Meter setup? cloud_9 Electric Plane Talk 4 Nov 23, 2013 08:31 PM
Sold 2) 10 Pack Boxes of NIB NGK BMR7A Spark Plugs $18.00 ea. Pack stevster Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jan 27, 2013 09:13 AM
Question tips 4 replacing bad NiMH cells in a pack Ahmed Batteries and Chargers 4 Dec 30, 2008 05:38 PM
Tip: If you cut the plug off a battery pack dont cut through both wires together! trevsie Electric Plane Talk 22 May 25, 2001 02:03 PM
Tip: If you cut the plug off a battery pack dont cut through both wires together! trevsie Foamies (Kits) 1 May 22, 2001 09:19 PM
