Old Oct 15, 2012, 07:14 PM
Joined Jun 2006
Help!
collective swash plate opposite servo direction
hi guys i am a newbie regarding to FBL , i have been on rc for 7 years now. i am so puzzled regarding my copter x 450 set up with a standard cx1x1000 3 axis gyro. been using the FBL software too. i can not let the collective servos move up as i throttle up my tx, instead the servos goes down but the blade gives a positive pitch which is right but the swash and servos i don't thinks so. been thinkering this for two week now but i've never been to a solution. i flipped the blade grips already and reverse the pitch servos but nothing happens. i also reverse the collective adjustments on the software still nothing. can anybody help me with ? or can i fly this bird with this set up? i am planning for a 3D practice.
thanks you so much for bearing my problem.
mbagawin is offline Find More Posts by mbagawin
Old Oct 16, 2012, 03:58 AM
Texas NewB
Black_heart's Avatar
United States, MD, Princess Anne
Joined Dec 2011
to get the collective pitch going up on with throttle up set your numbers to negative in the Setup->Collective Pitch tab in the software.
Black_heart is offline Find More Posts by Black_heart
Old Oct 16, 2012, 06:07 AM
Joined Jun 2006
Thanks Black_heart!!
i knew where i made a mistake, i copied the head ( blade grips) from my flybarred copter x 450, so assuming that it is the same config, surprisingly upon investigation thru the web, my config was all wrong, so i flipped back the blade grips and install the bldes ,leading edge against the control balls, what a clever design by align (DFC system).
Discussion dual swash plate fixed pitch / or all out collective Madguns Coaxial Helicopters 6 Sep 21, 2012 10:46 AM
Discussion Possible to take out the motor shaft and mount it the opposite direction? Koo Power Systems 2 Aug 02, 2012 03:49 PM
Wanted swash plate leveling tool & aluminum tail servo holder nitrodude71 Aircraft - General - Miscellaneous (FS/W) 5 Mar 23, 2008 08:54 AM
Discussion A swash plate question for Lama (V3 or V4) owners with long servo horns e30ernest Coaxial Helicopters 11 Feb 13, 2008 07:56 PM
Wanted swash plate leveling tool & aluminum tail servo holder nitrodude71 Aircraft - Electric - Helis (FS/W) 0 Feb 04, 2008 11:00 AM
