Old Apr 10, 2012, 05:09 PM
PA44Capt's Avatar
Joined Jan 2009
Help!
AR6115e Won't Enter Bind Mode
I decided I was tired of being the only 72mhz guy on the field so recently I shelved my trusty (working) JR 6102 and got the DX8 with the two free receiver deal.
Now I am trying to bind the Ar6115e with the DX8 and the AR6115e WILL NOT enter bind mode. According to the instructions, when you have an ESC that provides rx power, you are supposed to plug the wire from the ESC to the throttle position and put the bind plug on bind/data then apply batter power.
When I do that, I'm SUPPOSSED to see a flashing orange light to indicate the rx is in bind mode but that doesn't happen. I've tried binding other receivers with no problem but this rx just won't go into bind mode.
What's the deal???......missing my 6102 already
PA44Capt is offline Find More Posts by PA44Capt
Old Apr 10, 2012, 05:18 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Have you tried binding the other receivers yet? It could be the bind plug, battery in incorrectly, or other things.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Apr 10, 2012, 05:33 PM
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
Originally Posted by PA44Capt View Post
... What's the deal???......missing my 6102 already
You can connect the esc or any power source with the proper voltage to any of the ports on the rx leaving the Batt/BIND/Data port free for the bind plug.
Make sure bind plug is properly seated, connect power and of course LED should be flashing.
Now if you are not even getting to this point but have bound other RX with the same plug, chances are the problem lies with that RX and if you bought localy you could go back with the components to get first hand help and they might be able to exchange the RX right there for you. (maybe)
Good luck..
freechip is online now Find More Posts by freechip
Old Apr 11, 2012, 03:27 PM
PA44Capt's Avatar
Joined Jan 2009
Thanks for the responses guys. I wish I could blame the problem on a faulty rx or bad battery but unfortunately the problem is a faulty modeler.....
So it turns out that if you plug the power line in backwards that the LED's on the receiver WILL come on, but will not do anything else. When you turn the plug around the other way with the bind plug in, everything works as advertised.
In my defense, the rx is labeled poorly as to which way is the correct polarity but....that's a pretty weak defense. Woops
Old Apr 11, 2012, 03:34 PM
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
- means negative
+ means positive
~ means signal
In almost all cases the pins closest to the edge are the negative. Where the pins are on the side then the pins near the bottom are the negative.
The important thing is you got it figured out now and can go fly.
Old Apr 11, 2012, 10:09 PM
High Voltage
dhf23's Avatar
United States, GA, Kennesaw
Joined Oct 2011
Ive have had two of these recievers in a couple of my foamies and have had nothing but problems with them. One of them lock out and crashed one of my planes and I sent another back to Horizon because it wouldnt power up anymore ( solid red light ). A friend of mine had the same thing happened. They are junk so beware. The ar500 are better as well as the ar6200..
dhf23 is offline Find More Posts by dhf23
Old Apr 12, 2012, 12:32 AM
Buschbarber's Avatar
United States, NY, Rochester
Joined Apr 2004
I have an AR6115 and I have never had a problem. It is installed in an Eflite Extra 300. I have been using it with the TM1000 and the Temp and Brushless RPM sensors.
Buschbarber is offline Find More Posts by Buschbarber
Old Apr 12, 2012, 12:44 AM
Joined Apr 2004
I am surprised that the connector from the ESC could be connected both ways. Spektrum servo ports have a very tight tolerance. Many JR/Spektrum compatible connectors are difficult to insert into a servo port with the correct polarity, let alone backwards. Usually, the polarity diagram is printed on the top label of the Rx.Since the Red wire is the Center wire, reversing it should not power the Rx
Old Apr 12, 2012, 05:44 AM
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
Originally Posted by dhf23 View Post
.... They are junk so beware. The ar500 are better as well as the ar6200..
And yet a large batch of AR500 did have issues and it's replaced by the AR600.
Never had issues with the AR500 and still use several of them and never had an issue with the above receiver also.
Old Apr 12, 2012, 08:39 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
You've been buying hard-case receivers, Rich.
The AR61xx line has soft cases. You need to look at the case to see the polarity, it's not molded into the plastic.
Andy
Site Sponsor
Old Apr 12, 2012, 09:13 AM
Joined Apr 2004
Andy
Thanks!!
Old Jul 03, 2012, 03:03 AM
Australia, QLD, Twin Waters
Joined Apr 2011
DX6 is not complatable with AR6115e
have a look at the Spectrum web site. It states in the section on the AR6115e that it is not compatible with the DX6....................then why do they sell them in the same box as a bonus? Alex in Australia
cunningbaldrick is offline Find More Posts by cunningbaldrick
Old Jul 03, 2012, 03:08 AM
Kambalunga's Avatar
Deutschland, Hessen, LA
Joined Jan 2009
Maybe why the sell DX6i and not DX6.
Kambalunga is online now Find More Posts by Kambalunga
Old Jul 03, 2012, 08:24 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
We haven't sold DX6's in ages. In fact, we had a buy-back/upgrade program for them a while ago.
Andy
Site Sponsor
Old Jul 03, 2012, 02:26 PM
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
I think you are talking about the DX6i, which definitely IS compatible with the AR6115e. As others have pointed out, the DX6 is long obsolete.
Daedalus66 is offline Find More Posts by Daedalus66
Help! FS-TH9X won't bind to reciever! gmwahl Radios 10 Dec 01, 2012 11:24 AM
Help! Hitech Aurora9 won't bind BillzillaAus Radios 15 Apr 02, 2012 12:40 AM
Help! Dx6i and orange rx won't bind supercublpflier Radios 2 Mar 03, 2012 06:33 PM
Help! dx6i wont enter bind mode roachslayer Micro Helis 12 Jul 19, 2011 11:06 AM
Hacker ESC won't enter programming mode stumax Power Systems 2 Nov 12, 2004 04:52 PM
