Closed Thread
Old Jan 08, 2011, 10:37 PM
Gravity - It's the law
Yabba's Avatar
USA, CO, Denver
Joined Jul 2008
Originally Posted by Tom Frank View Post
My HD key cam arrived today! >>snip<< My condolences to Saints fans!
Congratulations on both counts.
How bout them Broncos!!
Yabba
Yabba is offline Find More Posts by Yabba
Old Jan 08, 2011, 11:57 PM
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Initial camera checkout and comments
I've finished some initial sample clips and tests with my HD key cam, shot indoors with just natural window light, and outdoors in both cloudy (but bright) and full sun. My first impressions of the video are that the contrast and color saturation on mine is slightly over-stated, but I can correct that during editing. The vinetteing in the corners is there, but it's not too bad fortunately. My focus can use a little tweaking, but overall I'm very happy with the video.
Interestingly, the video bit rate in my 4 sample clips ranged from 7111 to 7605 kbps which is a bit higher than clips the vendors furnished. So, I set my average bit rate at 7400 kbps in AviDemux when I compiled and trimmed the clips rather than the 7000 kbps setting I recommended in my AviDemux Tips and Tricks post. So I'd say to check the average data rate on your native videos before re-encoding them, and set AviDemux accordingly. With Windows, just right click on the icon and select "Properties/Details" to show the data rate.
My next test was to check the 20 minute close-and-continue recording function, which work exactly as advertised, and when the battery ran low the last clip closed properly before the camera shut down. The delay between closing/saving one video and starting the next is one is only 3 seconds!
I then checked the web cam function, which also worked well. The video image is reduced to 640x480 for this function, and the white balance is a little off toward the red side on my monitor compared to other web cams I have, but is not too bad. And the extremely sharp image makes up for it. I have less than 1/2 sec. delay in video motion on my computer.
Finally, I did the dreaded date removal firmware replacement. After I copied the new firmware file to my card, I pushed the ON button and held my breath. After a 4-5 sec. delay, the yellow LED came on I was able to breath again. Success, and it was really an easy update process compared to that needed to remove the date stamp on the old 808 camera.
I'll check out the car charger cord tomorrow and maybe refocus if it's a sunny day.
Initial Clips with HD Key Cam (3 min 19 sec)
Tom Frank is offline Find More Posts by Tom Frank
Old Jan 09, 2011, 12:16 AM
wallaguest1's Avatar
Joined Nov 2006
nice video Tom Frank, i want one!
i notice a strange and repetitive noise in the video, at 0:52 in advance can be listened more clearly,
at 1:47 in advance disappeared apparently
wallaguest1 is offline Find More Posts by wallaguest1
Old Jan 09, 2011, 12:17 AM
RADAR_66's Avatar
Detroit, MI
Joined Dec 2010
808HD ipad (1 min 15 sec)
....just showing my buddy the new cam
RADAR_66 is offline Find More Posts by RADAR_66
Old Jan 09, 2011, 12:21 AM
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
It's a keeper Tom.
Prof100 is offline Find More Posts by Prof100
Old Jan 09, 2011, 12:47 AM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
I hadn't noticed that when I compiled the video since I had the sound turned down, plus my hearing at certain frequencies isn't all that hot. But, I turned up the sounds and could hear what you heard.
It sounds like short buzz sounds at about 1 sec. intervals. I thought that might have been something that crept in during the conversion from the native audio to MP3 during the re-encoding, but I could also hear it in the native clip. I have no idea what was causing that. I didn't hear it in the the sunny clip in front of my house... just in the back near the door and inside when downstairs. I have wireless internet and wireless digital phone soures near that area, etc. It might have been some kind of RF interference being picked up by the camera?
I'll shoot some more clips away from the house tomorrow and see if it goes away.
Old Jan 09, 2011, 01:12 AM
Joined Nov 2006
i have tested several "camera pens" and in some of them i noticed similar sounds.
i end up concluding it was CPU noise poorly filtered in the circuit.
But as i said its strange because is just noticeable in a part of the video,
i guess it was not a continuous shoot, so maybe the sound becomes picked just sometimes? strange...
maybe i am wrong but i wouldn't bet for the RF option, they probably have a very low output power to interference in such thing,
let me know your test results, cheers
Old Jan 09, 2011, 06:06 AM
Joined Jan 2011
Originally Posted by clx1 View Post
This is exactly what mine was doing before I sent it back to China. Looks like there is no FIFO in their inventory as Dec 17/Jan 6 is pretty late and there have been many who successfully removed the date stamp with earlier cams.
Did you order it from eletoponline, because mine was shipped from Singapore?
So far the seller hasn't contacted me back. Did your seller ask you to send it back or did you just send it?
Originally Posted by wayback View Post
Did you try the trick that worked on a lot of #3's? Remove the SD card, then turn on the camera. The #3 would blink 30 times, then shut down automatically. Put the SD card back in, power up, and see if it works. Well, worth a try at least.
Already tried that. It used to work on one of my old #3's but not on the #11.
Anyways, before I bricked it I recorded a small clip just for testing purposes with the date/time stamp still there. Its only 25MB, so if anyone with greater knowledge wants to have a look or compare it to his own HD cam... maybe it helps identifying the version of the cams.
http://rapidshare.com/files/441605390/PTDC0001.MOV
deepinside is offline Find More Posts by deepinside
Old Jan 09, 2011, 08:35 AM
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
Well Rome was built brick by brick..Ugh sorry
Here's what MediaInfo says about your file. Looks typical, from what I remember.
D:\PTDC0001.MOV;MPEG-4;;;;QuickTime;;qt ;;;;24.0 MiB;19s 0ms;;;;10.6 Mbps;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;UTC 2004-01-01 00:00:00;UTC 2004-01-01 00:00:00;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;1;;AVC;Advanced Video Codec;;;Main@L5.0;;;;;;;Yes;1 frame;;;;;;avc1;Advanced Video Coding;;;19s 0ms;;Variable;10.1 Mbps;;;;1 280 pixels;;720 pixels;;16:9;;;Constant;;30.000 fps;;;;;;YUV;4:2:0;8 bits;Progressive;;0.365;22.8 MiB (95%);;;;;;English;;UTC 2004-01-01 00:00:00;UTC 2004-01-01 00:00:00;;2;;PCM;;;;;;;;;;;;Little;Signed;;;;;sowt ;;;;19s 0ms;Constant;512 Kbps;;;;1 channel;;32.0 KHz;16 bits;;;;;1.16 MiB (5%);;;;;;;English;;UTC 2004-01-01 00:00:00;UTC 2004-01-01 00:00:00
If you had a JPEG still image, it might contain a lot more clues.
Here's the data from vendor sample "girls with bicycle"
D:\PTDC0002.MOV;MPEG-4;;;;QuickTime;;qt ;;;;16.1 MiB;19s 0ms;;;;7 091 Kbps;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;UTC 2004-01-01 00:00:00;UTC 2004-01-01 00:00:00;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;1;;AVC;Advanced Video Codec;;;Main@L5.0;;;;;;;Yes;1 frame;;;;;;avc1;Advanced Video Coding;;;19s 0ms;;Variable;6 577 Kbps;;;;1 280 pixels;;720 pixels;;16:9;;;Constant;;30.000 fps;;;;;;YUV;4:2:0;8 bits;Progressive;;0.238;14.9 MiB (93%);;;;;;English;;UTC 2004-01-01 00:00:00;UTC 2004-01-01 00:00:00;;2;;PCM;;;;;;;;;;;;Little;Signed;;;;;sowt ;;;;19s 0ms;Constant;512 Kbps;;;;1 channel;;32.0 KHz;16 bits;;;;;1.16 MiB (7%);;;;;;;English;;UTC 2004-01-01 00:00:00;UTC 2004-01-01 00:00:00
Here's "car on bridge" vendor sample
D:\PTDC0038.MOV;MPEG-4;;;;QuickTime;;qt ;;;;49.6 MiB;59s 0ms;;;;7 051 Kbps;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;UTC 2004-01-01 00:00:00;UTC 2004-01-01 00:00:00;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;1;;AVC;Advanced Video Codec;;;Main@L5.0;;;;;;;Yes;1 frame;;;;;;avc1;Advanced Video Coding;;;59s 0ms;;Variable;6 537 Kbps;;;;1 280 pixels;;720 pixels;;16:9;;;Constant;;30.000 fps;;;;;;YUV;4:2:0;8 bits;Progressive;;0.236;46.0 MiB (93%);;;;;;English;;UTC 2004-01-01 00:00:00;UTC 2004-01-01 00:00:00;;2;;PCM;;;;;;;;;;;;Little;Signed;;;;;sowt ;;;;59s 0ms;Constant;512 Kbps;;;;1 channel;;32.0 KHz;16 bits;;;;;3.60 MiB (7%);;;;;;;English;;UTC 2004-01-01 00:00:00;UTC 2004-01-01 00:00:00
So vendor samples have lower bitrate, but that's been seen by Jantares after taking JPEGs
victapilot is offline Find More Posts by victapilot
Old Jan 09, 2011, 10:01 AM
Joined Dec 2010
Tom,
Congratulations on finally getting the cam in your hands and successfully doing the date removal! Mine also arrived, without the date stamp to boot. So it appears that the vendor is a pretty good bunch, do good work and value good customer relations! I am happy. Thanks for all your efforts and I will continue to wade in and see what I find on this wonderful thread from time to time.
clx1
clx1 is offline Find More Posts by clx1
Old Jan 09, 2011, 10:15 AM
mavlo77's Avatar
The Netherlands
Joined Oct 2008
http://www.vimeo.com/18579886
Cool! Looks like the focus is OK?
In numberz the increase from 480p to 720p doesn't sound so much, but looking to your video in full screen, it is certainly a significant step up from the #3 in terms of definition!
Can't wait to receive my camera and film onboard!
mavlo77 is offline Find More Posts by mavlo77
Old Jan 09, 2011, 11:52 AM
Joined Jan 2011
Hmm... strange, played around a bit, got my HD to work again to full functionality and could even remove the date/timp stamp. Heres what I did.
After trying to remove the date/time stamp using the adapter I wouldn't get the yellow LED to come on anymore, though the red one was working fine.
I removed the formatted flash card from the cam (the one which I tried to remove the date/time stamp with before) and put it in the adapter. I then copied the "Date On" bin-file "FW96630A.bin" to the root of the flash card with the DCIM folder missing. I removed adapter and flash card and put the card back into the cam. It wouldn't start (no yellow LED).
I connected the cam to the computer via USB. The red LED came on. The cam wasn't recognized as a mass storage device. After about a minute I pressed the POWER button for about five seconds and the yellow LED came on and the cam appeared as a mass storage device with the DCIM folder and the bin-file present. I removed only the bin-file.
I pressed the power button again for about a second and the yellow LED disappeared and the red one appeared. The cam wasn't recognized as a mass storage device anymore. I unplugged the cam so that the red LED was gone.
I then could start the cam normally. Both video and photo were working fine with the date/time stamp present.
I then used losthelis instructions from post #108 to remove the date/time stamp, this time avoiding the adapter and using the solution via direct USB connection (with the DCIM folder still on the flash card and using FW96630A.bin from the "Date Off" folder).
Everything works fine.
Heres a photo from the cam with EXIF data:
http://img84.imageshack.us/img84/7718/ptdc0002.jpg
Old Jan 09, 2011, 11:54 AM
Joined Jun 2010
Does anyone have the following problems?
Date time does not keep very well, gained 14 days in a week.
Low light situations do not film well.
Stopped taking pics, this one has me scratching the noggin, as I used to have no trouble taking pics.
Jazz
jazz53 is offline Find More Posts by jazz53
Old Jan 09, 2011, 12:25 PM
victapilot's Avatar
Joined Feb 2009
That's great work, deepinside!
Here's a shot of the EXIF data, good for comparison
Old Jan 09, 2011, 12:55 PM
jantares's Avatar
Poland
Joined Dec 2010
I wonder if your 808HD only be unblocked and able to upload new firmware with the date and time. Do you still record video in over 10000kbps?
Have you used the firmware to remove the date and time?
jantares is offline Find More Posts by jantares
Closed Thread
Video Samurai with key cam AeroNut45 Electric Plane Talk 2 Oct 30, 2010 11:40 PM
Found found beladog FPV Equipment (FS/W) 1 Oct 30, 2010 01:01 PM
Discussion Any sign of True real time HD FPV gear....not secondary HD CAM ???!! khaled_abobakr FPV Talk 8 Oct 10, 2010 07:13 AM
Mini-Review Key Chain Cam for your autogyro!!! imsofaman Auto Gyros 7 Sep 10, 2010 07:10 AM
