Old May 18, 2011, 01:16 PM
Fly like never crash as always
tascheri's Avatar
Rio de Janeiro
Joined Mar 2007
Finally took a deep breath and jumped on it. Took me less than 1 hour to do my first and I fumbled a lot to solder in order to get it perfect.
RHCP, right?
I donīt bank a lot with my EZ ( at least when Iīm far away ), thatīs why I chose this one for the aerial.
My immediate intentions are to cover my GP patch reflector corner and use it with this one.
sanity check someone??
tascheri is offline Find More Posts by tascheri
Old May 18, 2011, 01:20 PM
ysb
use the force..or a quadcopter
ysb's Avatar
quebec
Joined Dec 2010
Originally Posted by cncoz View Post
For what It's worth...
I made a set of CP's for my 5.8Ghz parkflier, hope to try them tomorrow.
I worked this template out to help with bending, might be useful to someone.
If the antennae perform well I'll post pics.
Cheers !
thanks i will check my Cloverleaf on this template
ysb is offline Find More Posts by ysb
Old May 18, 2011, 01:42 PM
Oh so close!
clipper99's Avatar
Campbell River
Joined Jan 2010
Use this for my router?
Sorry to go off-topic for a second.
If I build a 2.4ghz version and modify my stock whip antenna that came with my router would I get better range? I'm over a my neighbours place a lot and get spotty reception. Maybe this might help? If I do build one just orient it so it is facing up?
cheers
clipper99 is offline Find More Posts by clipper99
Old May 18, 2011, 02:28 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
cheers
It's hard to say. My first though is probably not. However a 3/2 wave dipole would do pretty well.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old May 18, 2011, 02:29 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
RHCP, right?
That looks pretty good to me. I see you reversed you GP patch panel like I suggested. Watch how clean your video is now.
-Alex
Old May 18, 2011, 03:05 PM
tascheri's Avatar
Rio de Janeiro
Joined Mar 2007
-Alex
thx buddy! Rain is fading and the weekend is going to rock!! too bad my GS DVR had to be returned and I wonīt be able to share video.
in fact I had built the GP like that from the beginning, I didnīt go back to look at pictures after I printed the template and it just came out like that.
BTW, Iīm using aluminum panels with small tin squares riveted to it ( thatīs where I solder the connections ). Do you see any issues?? Should I still cover the dog ear on the reflector or just test it like that??
sorry to bother you again.
Old May 18, 2011, 09:22 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I think you'll be ok with it how it is. The GP patch is a copy of K5OE's dual band patch for dish feed which was designed back in the 1950's. The trimming of the corners was to allow the second patch to radiate at the fringes.
-Alex
Old May 21, 2011, 09:50 AM
tascheri's Avatar
Rio de Janeiro
Joined Mar 2007
Alex, your really got me... best video ever... I took my vee to compare but I never bothered to even mount it. the static is less than seldom. Lost signal behind a mountain but I was really pushing it low on the other side...just eased on the elevator and signal came back in less than a second. got some static flying 3 meters high and 200 meters away but right in the beam of a very big cell phone mast. flew a mile upwind with absolutely no degradation.
Almost lost my plane today... I did a very stupid thing, my Video Bat + wire got loose of the connector so I flew off the charging connector... It was good down to 10.9 volts... but then.... just lost it completely in a flash... I was 600 m away and donīt ask me how I spotted it because I donīt know... My 2 spotters only saw it when I was like 200 m away..
Old May 21, 2011, 10:39 AM
la fabrique circulaire
terry74's Avatar
geneva
my Skew-Planar
if you want more detail about building, it is here
terry74 is offline Find More Posts by terry74
Old May 21, 2011, 10:44 PM
Glenstr's Avatar
Canada, AB, Lac La Biche
Joined Aug 2010
I just bought one of these from RMRC, a set with the cloverleaf. I have the inverted vee on my plane, and I'm going to use this with my Eagle Eyes diversity feature.
I'll try this first, then the cloverleaf and see how much difference there is.
I just modified my ground station last night, here it is with the mods:
Glenstr is offline Find More Posts by Glenstr
Old May 22, 2011, 08:23 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Put the cloverleaf on the plane and forget the Vee. There is hardly any comparison. It's that good
-Alex
Old May 22, 2011, 09:12 PM
Glenstr's Avatar
Joined Aug 2010
-Alex
I was thinking about that, but I thought you mentioned one other time the Vee might be better for when I dip below the treeline.
My Cloverleaf is the blubeam without the cable, so should I just turn the tx where it is and stick it on there? (see pic's) Or should I put it up front just behind the prop, which is the highest point on the plane.
Old May 23, 2011, 04:42 AM
Spain
Joined May 2011
Can I use 1.1mm thickness galvanized steel to build this antenna (and the cloverleaf) for 1280mhz?
thanks
datyip is offline Find More Posts by datyip
Old May 23, 2011, 07:32 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The Vee/Biquad will do better when dipping behind trees, but in general the CL/SPW is the absolute best antenna combination you can fly.
Old May 23, 2011, 07:33 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
thanks
You meant the patch? yes. The Skew-wheel and cloverleaf? If it's 1.1mm wire, yes. I never thought about it, but bailing wire would probably work fine for this antenna too.
-Alex
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 53 Feb 21, 2015 07:02 PM
Mini-HowTo DIY Ground Plane omni directional RX antenna IBCrazy FPV Talk 60 Nov 19, 2012 06:11 AM
Discussion 900 mhz circular polarized antenna? g00bd0g FPV Talk 9 Aug 21, 2012 09:54 AM
Discussion 18dbi Circular Polarized Patch ? Coyote64 FPV Talk 3 Nov 10, 2010 04:59 PM
Question Circular polarized antenna question Sov4life FPV Talk 8 Mar 05, 2010 05:00 PM
