Old Apr 01, 2003, 12:10 AM
AMA3655@aol.com
Guest
n/a Posts
[RCSE] Servo mounts
Andrew -
I just finished putting my Tsunami together. The 5125 fits well in the wing, and it's the only digital servo currently available that will fit. I made some mounts out of that little known natural composite, wood. They were easy to fabricate, they work well, and they are light. I noted that the aluminum mounts add 1.5mm to the servo depth. You really don't need that in the Tsunami wing, it's pretty thin. I suppose that you could mill them down, but that would take more time than just making wood ones.
happy trails - Rob Glover
> The servo discussions comes at an opportune time; Arend Borst
> just e-mailed me my Tsunami is on the way and asked if I
> wanted
> servos with it
> Looking over on Glider King, I saw this:
> http://home.earthlink.net/~crg13/framepage.html
> Thought some people here might be interested.
> Andrew E. Mileski
> Ottawa, Canada
RCSE-List facilities provided by Model Airplane News. Send "subscribe" and "unsubscribe" requests to soaring-request@airage.com. Please note that subscribe and unsubscribe messages must be sent in text only format with MIME turned off.
AMA3655@aol.com
Guest
n/a Posts
Re: [RCSE] Servo mounts
Craig -
Whoops, I thought that protos were what was available. Sorry, I'll post this to the exchange to point out my error.
BTW -the frames look way cool. The lightening/glue holes are really classy.I'm not sure how you can sell them so cheap. I like my wooden ones, but to tell the truth if I had known yours were available I'd have probably used them and left the servo covers off so folks could see them. Maybe you should make a clear servo cover to go with them. And you could anodize the frames to color match the plane...
happy trails - and good luck -
Rob Glover
> Rob,
> Pretty sure I put on that page that only the proto frames
> are
> deeper, new run units are flush. I have wood frames in my
> Xtreme.... :-)
> CG.
Kyosho F16 servo mounts? gen Electric Ducted Fan Jet Talk 2 Oct 07, 2003 09:18 AM
T-IFO servo mounts scruz Scratchbuilt Indoor and Micro Models 4 Mar 23, 2003 06:43 AM
Aluminum Servo mounts for 120 degree mixing on ECO-8! Jon h Electric Heli Talk 5 Jan 14, 2002 08:19 PM
servo mounts grr1941 Electric Plane Talk 0 Apr 26, 2001 02:21 PM
