Old Sep 21, 2007, 09:18 AM
Sponsored by Team Me
raynet11's Avatar
Montgomery, IL
Joined Aug 2005
Trex with HS-65 question:
I'm in the process of building my Trex 450S, I'm using HS-65's for the swash with the standard servo arms. In order to get the arms geometry correct I had to use the 2nd hole on the servo arm. It still looks like I have plenty of throw on the swash but I still couldn't help but wonder what hole everyone is using with their HS-65's?
cheers,
Ray
raynet11 is offline Find More Posts by raynet11
Latest blog entry: RC Storage:
Old Sep 21, 2007, 09:19 AM
Joined Apr 2006
using the second hole from the inside on the single long arm whcih gives way more than enough travel and your correct the symmetry is perfect here.
driftinsequence is offline Find More Posts by driftinsequence
Old Sep 21, 2007, 09:22 AM
raynet11's Avatar
Montgomery, IL
Joined Aug 2005
Thanks, so I should be good to go then.. I was worried a bit since on my other machines I was usually at the outer holes to get the same geometry.
Old Sep 21, 2007, 09:53 AM
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
You'd want optimum throw not maximum throw for cyclic. More is not always better for cyclic angles. You want to confine you pitch interaction to within 6-8 deg. Too much and the rotor could stall under certain maneuvers.
Gino CP is offline Find More Posts by Gino CP
Old Sep 21, 2007, 10:17 AM
raynet11's Avatar
Montgomery, IL
Joined Aug 2005
That brings up a good point Gino..
I always set for physical max throw but I never program more then 70% in my swash movement (usually it's more like 65). It also helps that as of late I prefer to have a max pitch of -9<->+9 but most of my setups can go -12<->+12, easy setups.. That doesn't mean that when your doing a new build though that you can put the pitch gauge away and just skip checking the interaction.
Sold Set of 3 Trex servos- HS 65 HB badbill Aircraft - Electric - Helis (FS/W) 1 May 25, 2007 11:10 AM
For Sale FS: Trex SE with HS 65 HB Eeeeky Aircraft - Electric - Helis (FS/W) 3 Jan 23, 2007 10:40 PM
Discussion Corona with HS-65 servos? wigeon Electric Heli Talk 4 Aug 04, 2006 10:12 AM
Question Trex tail wag with HS-56 servo? bkahuna Mini Helis 11 Mar 12, 2006 09:47 AM
Trex CCPM mod with HS-56HB servos tak Mini Helis 21 Feb 04, 2005 07:37 AM
