Old Dec 13, 2012, 08:35 AM
Joined Mar 2012
Hobbyking FW190
I have recently purchased the HK FW190. on the maiden everything went well untill i raised the wheels, at this point the trim changed massively and the model dived for the ground.
I managed to hold full up elevator and somehow flick the retract switch and order was restored.
The wheels appear to move up and down along a straight path so i dont believe the CofG moves.
Has anyone else experienced the same thing?
filstu is offline Find More Posts by filstu
Old Dec 19, 2012, 07:59 AM
Xanadu's Avatar
Canada, MB, Winnipeg
Joined Nov 2006
Sounds like the drag is quite hard with the gear down, and decreases severly once retracted. Yo should check the COG with the gear down versus retracted and see if a major differnace. Also make sure your battery is not shifting.
Did you balance it upside down, with the gear down?
Xanadu is offline Find More Posts by Xanadu
Discussion Yet another Guillows FW190 Electric Conversion ArtJ Scale Kit/Scratch Built 78 Mar 25, 2013 03:37 PM
Discussion *Hobbyking fw190 thread* CaptDH Electric Warbirds 105 Nov 11, 2012 09:21 AM
Build Log Vailly Aviation FW190 toxic-trip Fuel Warbirds 3 Mar 02, 2012 06:31 PM
Sold COX P-40 & FW190 Pair- New in Boxes Diane@lazertoyz Aircraft - Electric - Airplanes (FS/W) 7 Feb 27, 2012 03:57 AM
Discussion 荷蘭飛友寄來的A10 and FW190照片, Photos of A10 and FW190 coming from Netherland GWS CHEN Taiwan 2 Apr 16, 2008 05:56 AM
