Old Nov 19, 2014, 03:03 PM
ncflyer79's Avatar
United States, NC, Marion
Joined Jun 2011
Man this thread is dead. I was thinking about mine the other day and wishing I still had it and may get another. Wonder how its selling? if it hits the HH discount bin ill probably go for it. Craig whats the status with this bird. Horizon gonna keep it around for awhile?
ncflyer79 is offline Find More Posts by ncflyer79
Old Nov 19, 2014, 07:34 PM
Foam Wrecker
voidmix's Avatar
United States, NY, West Babylon
Joined May 2012
I hope so... getting one soon!
voidmix is offline Find More Posts by voidmix
Old Nov 30, 2014, 08:24 PM
Australia
Joined Jun 2007
hi guys, thanks for the very good info on this model. I am close to maiden on mine. Going electric.
I, like many others, have found it necessary to pack loads of lead in the nose to achieve COG. I am going for 80mm for COG. I've decided to go down the 2 x 6S lipo's instead of having dead weight. I've got one pushed right up against the firewall and another directly behind. I'm hoping this is going to give me a flight time of around 10 mins. I'll see how I go regarding the gyro for the rudder, I'll be prepared to yank in alot of right rudder for the take -off.
Interested to know if many others have got the 2 x 6S setup. btw, it is 2 x 6S 5000mA wired in parrell.
Regs,
Simon
sglnichols is offline Find More Posts by sglnichols
Old Dec 01, 2014, 04:28 AM
Germany, SH, Rellingen
Joined Sep 2010
How heavy will those be? My 5Ah packs weight around 820g, so using two of those would be a lot of extra weight I think.
/Malte
noradtux is online now Find More Posts by noradtux
Old Dec 01, 2014, 09:11 AM
This area for rent
Vestal, NY
Joined May 2006
i flew the H9 Spit on 6s5k25c for a while and got 7minute flights with a minute+ to land.
other equipment was:
castle ice 100
power 60
14x10 and 14x12 prop
Joe
paladin-34 is offline Find More Posts by paladin-34
Old Dec 01, 2014, 05:42 PM
Australia
Joined Jun 2007
all up weight is less than 6KG. Where is your COG guys? Seems like putting lots of weight on the nose end is the done thing going from what I have been reading. Joe, were you using 2 batt's?
Cheers
Old Dec 02, 2014, 11:50 AM
This area for rent
Vestal, NY
Joined May 2006
just 1 x 6s5k25c got 7 minutes plus 1 to land. burn rate was something like .540amps/ minute.
Takeoff was alittle nip and tuck with that settup (i fly in wind and it could not handle high winds). nothing a model flown in winds it was intended for will have problems with.
Joe
Old Dec 02, 2014, 01:52 PM
Ldm
Ldm's Avatar
United States, PA, Conestoga
Joined Jun 2006
Joe the H9 spit is much lighter then the CMP planes. Most of mine are 2x4cell and 2x 5cell
Ldm is offline Find More Posts by Ldm
Old Dec 02, 2014, 04:44 PM
This area for rent
Vestal, NY
Joined May 2006
and repairable which is why it was chosen for my wind flier. but the e-flite power 60 just did not cut it on takeoff in wind like i said above, oh we have really tall grass at our field(its a political thing, dont ask) making rotation speeds lower.
my electric setup of choise is:
5065-320
8s5k25c
100amp ESC
15x10 or 15x12
it will get me out of the grass (like a rocket if need be) and i can throttle back to realistic speeds once airborn. surprisingly the burn rate is lower with that setup 460ma/minute at full tilt. but when throttled back i can stretch the fllight to ten minutes with a burn rate of 400ma/m to 430 depending on the manuvers.
i know im running the motor in second gear but it works.
Joe
Old Dec 02, 2014, 10:54 PM
Australia
Joined Jun 2007
what is your all up weight and COG guys? I'm a little nervouse about mine now, lots of nose weight like this wasn't required on the H9 spit. Just to clarify, mine balances a slightyly nose heavy at 80mm from leading edge up against wing root.
cheers
Old Dec 03, 2014, 12:30 AM
Joined Oct 2007
Hi,
the all up weight of my BF-109 is 4.800g...
I use a 5S setup.
Best regards
Patrick
cupra4 is offline Find More Posts by cupra4
Old Dec 04, 2014, 01:22 AM
Australia
Joined Jun 2007
thanks for reply, maiden time next available weather slot!
Just a question about flaps......I have all 4 flaps controlled by the 1 channel. Am only planning on using them for landing. What have folks got setup for flap angle? 30 degs?
Cheers
Discussion Hangar 9 P-47 60 vs Spitfire 60 Rcflyyer1 Fuel Plane Talk 8 Dec 18, 2012 09:12 AM
Discussion Hangar 9 P-47 60 vs Spitfire 60 Rcflyyer1 Fuel Warbirds 5 Dec 09, 2012 04:36 AM
For Sale Messerschmitt Bf 109 Instrument Panel fits ESM 109 iflytailies Aircraft - General - Miscellaneous (FS/W) 0 Jun 16, 2012 11:47 AM
Sold Messerschmitt Bf 109 Instrument Panel fits ESM 109 iflytailies Aircraft - General - Miscellaneous (FS/W) 0 Apr 29, 2012 12:05 AM
Sold Messerschmitt Bf 109 Instrument Panel ESM 109 iflytailies Aircraft - General - Miscellaneous (FS/W) 0 Mar 18, 2012 11:53 PM
