Old May 18, 2012, 05:38 PM
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Mini-HowTo
Horten IV elevon linkage
After toying around a bit with this concept, I've come up with a rather easy method for what appears to be a very complex linkage arrangement. Materials are brass tubing, music wire and solder.
This prototype does not quite have the correct geometry with more deflection in one direction rather than the other, but overall deflection is good. Would require a very big arm on the servo to drive it. All do-able. Next time I'll use a drill press to drill the tubing for the axle.
Kent
Horten IV elevon linkage (0 min 22 sec)
Knoll53 is offline Find More Posts by Knoll53
Latest blog entry: Sw-11
Old May 19, 2012, 08:52 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Sorry, but here comes mister awkward.
Why have you made something so 'complicated' when individual servos working push rods to control horns are so easy ?
The rotating angled rod still seems to take up room within the wing section if it's for scale reasons, and you still need two servos.
Also if a totally hidden control was required, wouldn't an RDS drive be easier ?
Remote rds drive thread
But all that said, your mechanism is fascinating
eflightray is offline Find More Posts by eflightray
Old May 22, 2012, 03:53 PM
less is more
Knoll53's Avatar
Joined Sep 2006
Welcome mister awkward.
This is a scale version of the linkage used on the Horten IV. Just another unique example from a truly unique sailplane. Although my version is just a prototype, it is more robust than expected. With a little more development, it could be useful.
As you've noted, this linkage is entirely internal, like RDS. But unlike RDS, this linkage and tolerate sand, which is a given for me.
Also, multiple elevons could be operated by one pushrod. Although they are tied together by the pushrod, each elevon can have a different deflection, depending on geometry.
Kent
Link Full size Horten IV replica cpdude Scale Sailplanes 16 Sep 30, 2012 01:02 PM
Discussion Fully Molded 1/4 Scale Horten IV project Knoll53 Sailplane Talk 0 Dec 03, 2011 12:23 PM
1:1 Horten IV pictures max z Scale Sailplanes 19 Jan 15, 2005 07:12 AM
My next scale sloper project...the Horten IV surfimp Slope 9 Apr 30, 2003 11:12 AM
