Old May 27, 2008, 01:00 PM
roadsplat is offline
Find More Posts by roadsplat
Central Michigan
Joined Nov 2005
DX7 programming combine flaps and ailerons ..How?
I have a DX7 and would like to know how to program this so that I can combine the flaps with the ailerons (to achieve full length ailerons)
My wing has 4 servos. I am not particularly interested in having a "crow " function. I would like to just use the flap switch to control flaps where 1 position is up, 1 position is down, and the 3rd position combines them with the ailerons. Basically have the outer section work as a aileron all the time and the inner section work as either a normal flap or aileron.
I assume that this can be done, I'm just getting confused when I start messing with the program mixing screen. Any help and info would be greatly appreciated.
RC
roadsplat is offline Find More Posts by roadsplat
Old May 27, 2008, 01:39 PM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
To achieve full length ailerons, mix ailerons with flaps. I haven't done it but since DX7 has 6(?) free mix, it should have no difficulty.
However, if you were to use DX7 for 4 servo wing glider, you chose a wrong radio.
DX7 does not have a dedicated program for glider. I made the same mistake. I didn't know it before I bought it. It is incovenient to use DX7 for a full house glider.
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old May 28, 2008, 09:57 AM
Central Michigan
Joined Nov 2005
Yes I know that it can do it,but that is the problem. I am not sure how to setup the program mixes. Can someone post what steps I need to take to accomplish this.
RC
Old May 29, 2008, 10:03 PM
Central Michigan
Joined Nov 2005
Anyone???
Old May 29, 2008, 10:15 PM
areid is offline
Find More Posts by areid
Auckland New Zealand
Joined Aug 2007
See my post in http://www.rcgroups.com/forums/showthread.php?t=863368. Thats one way of doing it, I'm sure there are others....
areid is offline Find More Posts by areid
Old May 31, 2008, 10:13 AM
Central Michigan
Joined Nov 2005
Thanks for the link. I'll give that a try.
RC
Question DX7 Programming with Seperate Flaps UnPossible Radios 7 Jun 27, 2009 05:24 AM
Discussion DX7 Programming help - Flaps steve1814 Radios 1 Feb 29, 2008 07:13 PM
Question Programming 6EX for flaps/Splrs/Ailerons Scott Seidler Sailplane Talk 0 May 14, 2007 05:20 AM
Question EVO Programming for Hyper DL - Ailerons as Flaps for Launch John_R_C Hand Launch 10 Jul 07, 2005 10:53 AM
Flaps or spoilers, how do you slow a plane down? GregG High Performance 15 Sep 11, 2002 02:13 PM
