Old Mar 25, 2012, 07:41 AM
freechip is offline
Find More Posts by freechip
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
Check the servo monitor screen. Had my throttle do this sometime ago, it was very notchy on the monitor. It had been shelved for sometime and I guess it got dirty or something because after several minutes of playing with it it was back to working normally.
This might be something to look into, start with checking the monitor screen to see if the throttle channel moves smoothly or jumps.
freechip is offline Find More Posts by freechip
Old Mar 25, 2012, 08:42 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
I'll give the monitor screen a try, thanks.
Bill Glover is offline Find More Posts by Bill Glover
Old Mar 25, 2012, 05:22 PM
elau is offline
Find More Posts by elau
United States, FL
Joined Dec 2002
Hi. I attemped to fly yesterday but got this problem. My elevator stick seems to be stuck on the up position. I tried with two models and it always is elevator "up". Could this be related with the stick pot/potentiometer? I did follow the instructions on the service bulletin and my elevator does not move at all on the monitor display.
Seems I will have to ship it back to Horizon........
Is this issue still covered by Horizon or will be out of pocket?
elau is offline Find More Posts by elau
Old Mar 25, 2012, 05:24 PM
freechip is offline
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
Only HH could tell you if they will cover it or not. Either it sounds like it needs to be serviced.
Old Mar 26, 2012, 01:59 PM
Joined Nov 2000
My DX6i went back for the recall, so I'm going to be pretty unimpressed if it turns out a stick pot. problem is behind the occasional throttle weirdness I'm getting.
Old Mar 26, 2012, 03:50 PM
seefest is offline
Find More Posts by seefest
seefest's Avatar
United States, MA, Bristol
Joined Sep 2009
Let us know how you make out.
seefest is offline Find More Posts by seefest
Old Apr 05, 2012, 10:33 AM
Jonathan.kichizi is offline
Find More Posts by Jonathan.kichizi
United States, AZ, Tucson
Joined Aug 2011
Originally Posted by freechip View Post
Even if it did not have Model Match binding is part of the normal process of setting up a model along with setting up proper failsafe. Now if none of this is needed then technicaly you don't even have to change the model memory position.
If you do have to change it because that second plane is setup a different way then do yourself a favor and rebind.
The DX6i manual says that after you bind and setup everything, you should bind again to set up the failsafes. This was cryptic to me... what failsafes? What does the failsafe do?
Other questions... if the timer is set to the throttle cut button, will I kill the throttle when I arm the timer? (It didn't kill it when I tried it, but now I don't know if I completely removed the throttle cut functionality from the button by assigning it to the timer.) Also, after the timer counted down, it started beeping and I couldn't figure out how to turn the darn thing off. I hit the throttle cut button a bunch of times until finally the timer restarted. How do I just turn it off?
Jonathan.kichizi is offline Find More Posts by Jonathan.kichizi
Old Apr 05, 2012, 12:47 PM
freechip is offline
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
You bind once to gain control of the receiver and model, once you have setup reversing and stuff you bind again to set proper failsafe.
All of spektrum's receivers have smart failsafe which drives the throttle channel to the lowest position BUT this is set when you bind. So for what ever reason say you reversed the throttle channel in order for the model to function properly. If something was to happen and you lost signal to the model then the receiver would drive the throttle to the lowest position turning off the motor but if you failed to properly do the second bind after you reversed the channel then my friend you plane is out of control with the motor at full throttle.
NOT GOOD.
If you set the timer to count down then after the initial alarm the timer starts counting UP.
You if heard and alarm and it did not go off, is there a chance it could of been the low battery alarm of the radio?
Old Apr 05, 2012, 12:55 PM
quadracer is offline
Find More Posts by quadracer
No, I won't ship it. Don't ask
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
The throttle cut button must be set to ACT in the setup menu. Mine was INH from the factory. That's probably why yours isn't working.
quadracer is offline Find More Posts by quadracer
Old Apr 05, 2012, 09:48 PM
Great_Goose is offline
Find More Posts by Great_Goose
Flying from Vic Park
Great_Goose's Avatar
Australia, SA, Adelaide
Joined May 2011
I use the trainer switch as my timer start/ stop control, works well and easy to find without taking your eyes off the plane.
Great_Goose is offline Find More Posts by Great_Goose
Old Apr 06, 2012, 10:18 AM
Joined Aug 2011
Thanks freechip, quadracer, and Great Goose for the explanations. I understand the failsafe feature now.
So you're saying that once the timer counts down, it should beep a few times and then stop (and count up)? I doubt it was the low battery since it was the first time I'd used the transmitter.
Old Apr 06, 2012, 11:44 AM
freechip is offline
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
Haven't used my DX6i in some time but as I remember it yes, it counts down then does not stop when it counts down and reach zero it starts counting up.
When it does reach zero an alarm sounds for a little bit telling you you reached you set count down time. When you are done flying you stop the timer and can see how much more you flew or past your set timer.
Very usefull for certain things.
Old Apr 06, 2012, 12:18 PM
Brian VT is offline
Find More Posts by Brian VT
Brian VT's Avatar
United States, VT, Rutland
Joined Dec 2011
I just got a used DX6i.
Should the right stick (mode 2, ail/elev.) spring back to center from the left and right, or only from up and down ?
And the left stick (throttle/rudder) springs back to center from the left and right, and not from up and down ?
Brian VT is offline Find More Posts by Brian VT
Old Apr 06, 2012, 12:26 PM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Yes right stick springs to centre from both positions. Left stick only from left to right. Up down is throttle so that is positional.
Flypoppa is offline Find More Posts by Flypoppa
Old Apr 06, 2012, 12:33 PM
Brian VT is offline
Brian VT's Avatar
Joined Dec 2011
Not on the one I was sold. Bummer.
The Blade from Horizon Hobby avatar71 Micro Helis 0 Oct 04, 2005 01:39 PM
Discussion E-flite Ultimate Bipe from Horizon Hobby, where to find info??? Wild Bill 3D Flying 10 Oct 04, 2005 12:49 PM
Sold Brand new Advance 40 from horizon hobby argarre Aircraft - Fuel - Airplanes (FS/W) 8 Jul 15, 2005 10:45 PM
Sold Complete field kit from Horizon Hobby argarre Aircraft - Fuel - Airplanes (FS/W) 3 Jul 10, 2005 05:11 PM
Spam from Horizon Hobby Jim Taylor Vendor Talk 5 Nov 04, 2002 09:37 PM
