Old Jun 28, 2006, 01:20 AM
ToyBoy is offline
Find More Posts by ToyBoy
2 Mistakes Downwind
ToyBoy's Avatar
Portland, OR
Joined Nov 2004
What does "crack" mean? (balsa)
Yes, I am a total balsa newbie. Approaching 32 years of age and I finally decide it's time to start building balsa models. Anyway, I have this small rubber powered model kit here, and reading the instructions I notice "crack here" in a few places. What does this mean?
Are there any good resources on the web for balsa building newbies?
Thanks for suffering an idiot,
Murray
ToyBoy is offline Find More Posts by ToyBoy
Old Jun 28, 2006, 02:37 AM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Murray
Murray,
How about this?
http://pldaniels.com/flying/balsa/index.html
tim
tim hooper is offline Find More Posts by tim hooper
Old Jun 28, 2006, 03:00 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
More context might help but "Crack" in building instructions generally means what it does in conventional English. It's probably where there's a sharpish bend in a bit of wood and it means "Make a partial break in the wood by bending it sharply". When you try it you'll find the balsa doesn't completely break but just sort of changes direction . Doing it that way is a lot stronger than the alternative of trying to butt join 2 bits of wood together at an angle.
Steve
slipstick is offline Find More Posts by slipstick
Old Jun 28, 2006, 03:46 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Yes. Cut partially through with a razor saw or knife, or juts bend, and soak the join in thin CA...
Generally used to bring the top spar in a wing down to the wingtip smoothly.
Old Jun 28, 2006, 04:39 AM
the wiz is offline
Find More Posts by the wiz
the wiz's Avatar
Bullhead City Az.
Joined Jun 2006
here's a link i find helpful http://www.airfieldmodels.com/
the wiz
the wiz is offline Find More Posts by the wiz
Old Jun 28, 2006, 07:36 AM
perttime is offline
Find More Posts by perttime
perttime's Avatar
Tampere, Finland
Joined Nov 2004
You might get the "bend" also by pressing, on the inside, with a sharpish ruler before bending. Possibly less damage to the wood fibers.
perttime is offline Find More Posts by perttime
Old Jun 28, 2006, 11:37 AM
the-plumber is offline
Find More Posts by the-plumber
the-plumber
Joined Feb 2003
Dunno 'bout "crack here"; never seen that instruction, but my presumption is that it refers to wrapping balsa sheet around a tight radius and allowing the wood to fracture along the fold.
Might be worth trying a different method, spritzing household ammonia on the wood and bending it 'round the curve slowly. That's household ammonia as in "Parson's Household Ammonia", rather than some cleaning solution which has ammonia in it. The Parsons product doesn't have any perfumes or oils, and is about the strongest concentration of ammonia Joe Public can buy. This method works very well when you allow the ammonia to soak the balsa and bend slowly.
Otherwise, while not strictly a resources for balsa building, Thermal Thumbers are a prolific band of rubber builders, and it's likely they might be able to help.
the-plumber is offline Find More Posts by the-plumber
Old Jun 28, 2006, 05:32 PM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
No, bending will not do! You are trying to make an abrubt transition in a spar, not a gentle one.
In the good old days of balsa cement, a butt joint in end grain was a very weak affair..cracking the spar and rubbing cement in the crack as a simple and stronger way to achieve this.
Today probably sawing through and butting with CA or PVA would be just as good.
Old Jun 28, 2006, 11:21 PM
ToyBoy is offline
2 Mistakes Downwind
ToyBoy's Avatar
Portland, OR
Joined Nov 2004
Thanks for all your replies. They confirm what I assumed but I wanted to be sure.
the wiz: I agree Airfield Models is a great site for info, and I in fact checked his glossary for "crack" before posting my question here.
the-plumber: That Thermal Thumbers site is really interesting - thanks!
Old Jul 01, 2006, 02:21 AM
ToyBoy is offline
2 Mistakes Downwind
ToyBoy's Avatar
Portland, OR
Joined Nov 2004
Tim: somehow I missed your reply yesterday. Thanks for the link, looks like a very useful site.
Murray
Old Jul 02, 2006, 10:13 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Toyboy, they truly mean bend until it cracks and then add glue. The idea is that the wood will fail but the fibers will all fail at various points at or on either side of the break. Then when you add a touch of glue the glue bonds the overlapping fibers to give almost as strong a joint as if it was not broken in the first place. This is a fairly common technique for the smaller rubber models like Peanut Scales and other models of similar size.
If you find that the wood does not crack with a lot of fiberous interweaving then you (or the kit maker) picked the wrong peice of wood for that part. You want to test break the wood at one end to test for the proper sort of fiber breaking BEFORE you build it into a side frame or other application. Substitute strips until you find one that has the right fiber makeup at least at the one end and look it over carefully to see if it at least LOOKS like it'll retain that charactarsitic to the point where the crackN'glue joint needs to go.
Even for models of this sort where you're not going to crackn'glue it's wise to pick highly fibrous wood for longerons and stringers since they are less prone to failure.
BMatthews is offline Find More Posts by BMatthews
Old Jul 03, 2006, 03:03 AM
ToyBoy is offline
2 Mistakes Downwind
ToyBoy's Avatar
Portland, OR
Joined Nov 2004
Bruce, thanks for that excellent advice. You're right, the model I'm about to start is a small one (walnut scale). I almost started it this weekend but realized that I don't have a building board, so it will be delayed until I buy or make one.
TB
Old Jul 16, 2006, 09:39 PM
newguy is offline
Find More Posts by newguy
No retreat no surrender
newguy's Avatar
USA, WI, Milwaukee
Joined Apr 1999
The suggestion to partially saw through the piece is a good one. Andy Clancy used this method on his Lazy Bee kits. I have done this many times. Saw cut partially through the piece, "crack" it to the correct form, and then apply thin CA to the joint. Light, strong, and effective. Jim H
newguy is offline Find More Posts by newguy
Old Jul 17, 2006, 02:49 AM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Newguy, sawing cuts the fibers and totally messes up the strength of the joint. Glue is NOT a substitute for overlapping fibers that are glued together in the long grain direction.
I've never seen one of Andy's plans but if he's suggesting this method then it is a weak point and not a strong point. Either stick with the proper crack&glue or make a proper joint with a long angled overlap where the sharp "kink" is required. The fact that this style of joint is holding up well is due more to good luck and low stresses than to good design.
Old Jul 17, 2006, 08:32 AM
willin is offline
Find More Posts by willin
willin's Avatar
In my Blu heaven! near Lincoln NE
Joined Mar 2003
Mr Matthews is totally correct about the strength thing.
However with larger pieces of wood I have seen the instructions read "small cut on the top about half way through before you crack"
This is gone in order to be able to properly crack the thicker woods and allow tha upper half some room in which to move together and butt with the lower portion having all those overlapping fibers. I know it don't seem right somehow but it does work and still maintain a great deal of strength in the joint.
Probably not as strong as a simple cracked joint would.
I just can't see how it could. Keep, in mind that the thicker wood would not act the same and that the top of the crack(without the saw cut) would not crack properly but swimply snap in 2 because the top of the crack would act as a fulcrum.
Robert
willin is offline Find More Posts by willin
Battery Help??? mAh, volts, What does it all mean captian? Keitha Parkflyers 4 Mar 28, 2002 04:52 PM
NIB - what does it actually mean? fprintf Electric Plane Talk 17 Feb 27, 2002 08:25 PM
Matched cells… What does the label mean? paulaac Power Systems 3 Feb 15, 2002 04:05 PM
What does CAM mean? stuartaw Power Systems 3 Feb 14, 2002 11:53 PM
Question "balloon" what does this mean? omega blood Parkflyers 14 Jan 26, 2002 11:28 AM
