Old Jun 07, 2005, 02:17 PM
LouG is offline
Find More Posts by LouG
Joined Mar 2005
Problem with NiMh Pack & Jeti ESC
I'm using an 8 cell NiMh 1100 mah pack with a jeti 20 amp. ESC on a Graupner Speed 400 motor. The pack charges to 940-1080 mah at @ 11.6v. Twice now, I've gone to fly and when I advance the throttle the motor briefly starts and stops. I repeat this 3-4 times and the motor will eventually start but it doesn't seem to have the power I need. I'm confused and frustrated because every time I try to fly, some d--- problem always pops up. I've looked through the forums, is it the motor? I ran the motor WOT static 3-4 times before I flew it. I can't find any bad connections.
LouG is offline Find More Posts by LouG
Old Jun 07, 2005, 04:19 PM
BEC is online now
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Prop? Gear ratio? Which Graupner 400 (there are at least three)?
Which 1100s?
It sounds like your batteries aren't up to the load being asked of them and the low voltage cutoff is kicking in.
When you ran things statically, did you use the ESC?
BEC is online now Find More Posts by BEC
Old Jun 08, 2005, 04:31 AM
LouG is offline
Joined Mar 2005
It's a 9X5 slim prop, Graupner Speed 400, 2.33-1 gear ratio, Hobby-Lobby 1100mah (red packs). Can batteries look good on a charger and still have this problem? I would have to be immediately dropping 6.5v (from 11.6v) somewhere, for the ESC to kick in. I have another pack I will try.
Old Jun 08, 2005, 04:41 AM
damiens75 is offline
Find More Posts by damiens75
Sydney, Australia
Joined Dec 2004
Scratch this reply, i was thinking of a different esc
damiens75 is offline Find More Posts by damiens75
Old Jun 08, 2005, 06:53 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Are the batteries new? I experienced something like this with my first NiMhs, and found that I need to slooooow charge them first time round. Something like 100mA overnight. Then I got full capacity out of the cells and was able to charge them at 1C from then onwards.
abenn is offline Find More Posts by abenn
Alert Mini Gee Bee-Potential problem with 3S Lipoly and Jeti/Nippy combo skyyking Power Systems 1 Jan 08, 2004 08:29 PM
Do I have a problem with my GWS ICS50 ESC? Arthur_GA Power Systems 0 Jan 07, 2004 11:44 PM
Oscillation problem with Phoenix 45 and Jeti 30-3 iflyelectric Power Systems 4 Oct 02, 2003 04:27 AM
Problem With Pico Pack-how do I hook up? mrebman Parkflyers 5 Jul 06, 2001 11:06 AM
Problem with GP Electrifly C30 ESC Steph280 Electric Plane Talk 6 May 15, 2001 05:07 PM
