Old May 10, 2014, 05:16 PM
xenon20 is offline
Find More Posts by xenon20
Jet-Set !
xenon20's Avatar
United Kingdom, Clevedon
Joined Dec 2013
Help!
Choosing fan/motor/battery/esc for my air frame
Hi all
I'm building a 90mm Saab Viggen from D_Fast's plans in the EDF scratchbuild forum.
I'm afraid I don't know where to start with this. I did some calc's last night and reckon that my empty finished model will be about 1.5kg. I tried to estimate the AUW based on an 8S battery (?) which I estimated at roughly 3.7kg.
I am looking to fit a 90-100mm unit with a fairly realistic turbine sound. I already have 3x 4S 2200mah 35-70C lipo's which I would like to use if possible to save some cash.
What is the first step towards choosing a fan / motor / battery / esc combo ?
Lost on this so any advice is greatly appreciated
Paul
xenon20 is offline Find More Posts by xenon20
Old May 10, 2014, 05:29 PM
cbear is online now
Find More Posts by cbear
cbear's Avatar
jacksonville florida
Joined Feb 2005
Gary at e flux is who I went to, lots of choices. I, went with a jetfan 90 and het 700-68-1400 for my jet, figured I could use this on 8 or 10 c with a yep 120 hv speed control with the option to move to another jet in the future, some people go a different route, if you click on the jetfan 90 page on his sight it shows charts for each cell count and thrust, kind of put you in the ball park
cbear is online now Find More Posts by cbear
Old May 10, 2014, 05:32 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
jetfan 90
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old May 10, 2014, 06:05 PM
xenon20 is offline
Jet-Set !
xenon20's Avatar
Joined Dec 2013
Unfortunately I don't think the jetfan 90 is available in the UK ?
Old May 10, 2014, 07:43 PM
Joined Dec 2008
Get it right from Rainer.
http://shop.ejets.at/en/Ducted-Fan
Austria can't be to far away!
Old May 11, 2014, 03:10 AM
xenon20 is offline
Jet-Set !
xenon20's Avatar
Joined Dec 2013
I was on there last night but wasn't sure if they would deliver to me, so you own one ? What else have you owned and how does it stack up? What is it about it that makes you have so much praise for it? Please convince me to buy one !
Many thanks
Paul
Old May 11, 2014, 05:04 AM
Joined Dec 2008
Can't see why not? He has shipped to the USA.
so you own one ? Yes, and I will need one or two more
What else have you owned and how does it stack up? Dynamax, sold it to buy a Jetfan, decided to stick with 90mm sized fans. I never considered any other fan.
Excellent quality and workmanship for a fair price!
Please convince me to buy one ! Convince yourself, at least read the last 20 pages-- http://www.rcgroups.com/forums/showthread.php?t=1504718.... New JETFAN-90, or " The sound of silence?"
Many thanks
Paul
Cooler
Old May 11, 2014, 06:18 AM
Joined Dec 2008
Paul,
Check out the videos in these posts, planes are a touch bigger than your Viggen, but you get the idea.
http://www.rcgroups.com/forums/showp...&postcount=545
http://www.rcgroups.com/forums/showp...&postcount=628
http://www.rcgroups.com/forums/showp...postcount=1506
You also mentioned ESC and Batteries. A lot of guys have bought this ESC, I have 2 myself. (Good price couldn't help myself.)
Hobbyking YEP 120A HV (4~14S) Brushless Speed Controller (OPTO)
http://www.hobbyking.com/hobbyking/s...ler_OPTO_.html
Check here for a buddy code and save a few bucks. http://rcsearch.info/hobbyking/buddy/?strSearch=yep
You need to be signed in first to see discount price!!!
As for lipo's, you should be closer to 4400/5000mAh on 8s
Old May 11, 2014, 08:15 AM
xenon20 is offline
Jet-Set !
xenon20's Avatar
Joined Dec 2013
Thanks for the links.
So would my two 4S 2200mah packs (8S 4400mah total) not be up to the job then?
You mean I would need 2x 4S 5000mah (8S 1000mah total) ?
Ok so lets assume the following:
3.2kg AUW
Jetfan90-V2
HK YEP 120A HV controller
HET 700-68-1500 motor
So how do I calculate what battery is required?
Been looking at fancalc, motocalc etc but confused
Old May 12, 2014, 07:26 AM
MagnusEl is offline
Find More Posts by MagnusEl
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
With two 4 cells 2200 packs you can not get 8s 4400, only 8s 2200 if you put them in series, or 4s 4400 if you put them parallel.
MagnusEl is offline Find More Posts by MagnusEl
Old May 12, 2014, 01:10 PM
xenon20 is offline
Jet-Set !
xenon20's Avatar
Joined Dec 2013
Hi
Ok I've done a bit more research and I'm a (little) bit more clued up now.
I have done a new fancalc calculation (see attached) based on 2 4S 2200 packs connected in series to make an 8S 2200 35-70C pack.
I don't understand all the results but I was playing around with battery and motor combinations to see what would give me a thrust-weight ratio
of around 1:1. It seemed by uping the pack capacity to higher mah ratings were not making much difference to the thrust-weight ratio.
Could all you experts advise me what the most important data is when looking at my fancalc results, and whether the attached setup looks ok ?
Many thanks
Paul
Old May 15, 2014, 12:26 AM
charlieoneseven is offline
Find More Posts by charlieoneseven
Aircrafting is noisey...what?!
charlieoneseven's Avatar
United States, CA, Long Beach
Joined Dec 2005
The higher mah gives you longer flights and higher cell count makes the jet faster at wot.
Have fun what ever you go with. The nice thing is everything is swap able so if you don't like one try another. The jet fan is the coolest thing going out here as well but others are still spitting out plenty of sky.
charlieoneseven is offline Find More Posts by charlieoneseven
Discussion Older motors in newer fans for my Phase 3 F16 mistairjoe Foamy EDFs 0 Apr 10, 2014 06:39 PM
Wanted Sapac Viper MKII with Fan / Motor or air frame only yf22raptor Aircraft - Electric - Jets (FS/W) 1 Apr 21, 2011 09:47 AM
Discussion Can we move on from choo choo trains now? plowboy1966 Life, The Universe, and Politics 26 Mar 31, 2011 08:34 PM
Discussion Completed Project Choo...Choo... freddy warbird Life, The Universe, and Politics 9 Mar 27, 2011 04:00 PM
