Old May 02, 2014, 01:50 PM
boaterguy is offline
Find More Posts by boaterguy
Thermite + ice = Big boom.
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
Glueing blucore
I've seen a few threads about gluing blucore. Some have said no more nails works so I tried it. When I went to hotwire I realized that it doesn't cut very well, ruined my whole wing.
Hot glue cools too quickly, otherwise I would be using it.
So how can a glue blucore together so that it is still cuttable?
boaterguy is offline Find More Posts by boaterguy
Old May 02, 2014, 02:25 PM
Low and Slow is offline
Find More Posts by Low and Slow
United States, WA, Moses Lake
Joined Feb 2012
I've had pretty good luck with cheap elmers rubber cement. It hot wires fine. I get it at walmart most any craft store should have it.
Low and Slow is offline Find More Posts by Low and Slow
Old May 02, 2014, 05:50 PM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
I'll try that.
I asked at the hobby shop today and they said you can get the foam in up to 4" thick. Where can this be found? Lowes only seems to have 1/2"
Old May 03, 2014, 12:27 PM
Joined Feb 2012
The lowe's here has 3/4 and 1 inch in stock. They probably just don't carry it in the store but I bet you could order it online and have it shipped to the store for pickup.
Did you ask them if they could order it for you?
Old May 03, 2014, 02:51 PM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
I went to Rona and they had it. I got my cores cut and the plane is coming along nicely.
Are there any good strategies for building fuselages?
Old May 09, 2014, 04:34 PM
Pinky_d_brain is offline
Find More Posts by Pinky_d_brain
I don't do Normal
Pinky_d_brain's Avatar
Canada, NT, Yellowknife
Joined Dec 2011
I just go to a construction site and ask for some scrap and get it for free 1.5" is most common
http://www.homehardware.ca/en/rec/in...ded+Foam&Num=0
Pinky_d_brain is offline Find More Posts by Pinky_d_brain
Discussion Gorilla Glue or Hot Glue for FT Viggen shambopyro Foamy EDFs 2 Apr 10, 2014 10:38 AM
Discussion Blitzworks RC Sky Surfer V5 Assembly question - Glue or no Glue? pgallett Foamies (Kits) 1 Jan 27, 2014 07:15 PM
Discussion Anyone in the Tulsa area / Blucore foam BuckFuller Beginner Training Area (Aircraft-Electric) 3 Oct 10, 2013 03:22 PM
Question Glue Glue Glue??? mrichley Foamies (Kits) 8 Oct 05, 2003 09:56 PM
Glue? What to use on blucor? smaxwell Foamies (Kits) 15 Apr 03, 2003 10:25 PM
