This thread is privately moderated by bigburlybug, who may elect to delete unwanted replies.
Old Apr 09, 2014, 02:16 PM
sajeev is offline
Find More Posts by sajeev
United States, VA, Fairfax
Joined Feb 2004
You need to let the cap build up chArge. Then power on the rx
sajeev is offline Find More Posts by sajeev
Old Apr 09, 2014, 04:32 PM
bigburlybug is offline
Find More Posts by bigburlybug
Joined Mar 2014
The lipo is directly hooked up and it was puffed up which is undoubtedly from charging it incorrectly. Good thing I bought two Still working on the capacitor issue which would definitely be preferable. The plane can barely fly so any extra weight will make it drop and if I need bigger capacitors, that will probably be too much weight.
I waited long enough that the caps were charged and the extra current was going into the Rx making it turn on and off rapidly as if the capacitors weren't there. Turned on the Rx and it would blink irregularly. I'll play around with it some more to make sure though.
thanks for the input of the different battery types, I'll try to find some.
bigburlybug is offline Find More Posts by bigburlybug
Old Apr 09, 2014, 04:39 PM
sajeev is offline
Joined Feb 2004
LiPos need to be charged in a special way. I used to hook up NiCad to my car battery. But you have to be careful with LiPo. Charge it the wrong way and it will explode and probably cost you your plane
Old Apr 18, 2014, 01:45 PM
Joined Mar 2014
The End
We did not get the full 100 yards that the competition required. The plane made it 79 yards and the sun decided to hide behind a cloud. We charged the battery up before we took off a bit to try and prevent this but not enough. The plane made it the second furthest out of the competition with only a powered blimp making it to the finish line. With clear blue skies and strong sun, we would have made it without a problem.
So the final configuration of the plane was 10 solar panels, a motor for the ultra micro j3 piper cub, and 30 mAh hour lipo battery all wired together in parallel. I decided to switch out the Ember motor for the J3 piper cub in order to make the plane go faster. It needed more power so I got two more solar panels, which would also make it go faster. The project was a failure but next year it will be a success since we will have more time shave weight, get the center of gravity right, and know how much to precharge for specific sunlight conditions. There might be a video of it flying and the whole competition here in the future.
Thanks for all of the help
Contest Think of a competition competition!!! jasonfpvmodel FPV Talk 99 Nov 17, 2013 07:25 PM
Discussion smallest solar plane and solar car and solar mobile charger raazray Foamies (Scratchbuilt) 3 Aug 11, 2009 03:23 PM
Discussion solar plane,solar mobile charger,solar car raazray Flying Wings 3 Aug 10, 2009 02:21 PM
Discussion Check it: electric/solar boat competition! lakedude Life, The Universe, and Politics 10 Jun 19, 2007 11:05 PM
