Old Sep 18, 2013, 02:24 PM
Pedmondsonni is offline
Find More Posts by Pedmondsonni
United Kingdom, Craigavon
Joined Sep 2013
H9 spitfire damaged
What do I do? Today arrived my eagerly awaited h9 spitfire60 but the fin is broken at the very back and torn of at the front. do I return it or take a chance and stick it myself? Looks like it took a bad knock in transport.
Pedmondsonni is offline Find More Posts by Pedmondsonni
Old Sep 18, 2013, 05:15 PM
mike3976 is offline
Find More Posts by mike3976
Same Day Delivery
mike3976's Avatar
Economy, Pa.
Joined Mar 2002
Call Horizons toll free number, choose tech support, you will be prompted to leave a call back number, they will call you back. Explane your problem and you will have a new fusalage in 3or 4 days
mike3976 is offline Find More Posts by mike3976
Old Sep 18, 2013, 06:06 PM
helifann is offline
Find More Posts by helifann
Joined Dec 2005
That can be easy fixed, too bad it arrived that way, but easily fixed.
helifann is offline Find More Posts by helifann
Old Sep 18, 2013, 07:51 PM
JudahBenHur is offline
Find More Posts by JudahBenHur
JudahBenHur's Avatar
United States, PA, Towanda
Joined Sep 2012
You are better off calling them than trying to fix it yourself. Once you go that route, then all bets are off getting a replacement. They are pretty good on getting it right when things are damaged. They may have you send it in which is a bummer but they most likely will want a picture sent of the damage with a copy of the receipt. It will arrive in a few short days.
From my experience, those tail sections sure like to get smashed up. I wish the packing was a little more robust in that area.
JudahBenHur is offline Find More Posts by JudahBenHur
Old Sep 19, 2013, 06:55 AM
Joined Sep 2013
Seller says the UK distributer can't get a replacement for 4 weeks. I'll hold onto it and fix it up myself. The covering is my only gripe.
Old Sep 19, 2013, 07:09 AM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
Looks to me like it wasnt glued. I wonder if anything else in there wasnt glued?
Edwin
edwin1 is offline Find More Posts by edwin1
Old Sep 19, 2013, 12:07 PM
Hemikiller is offline
Find More Posts by Hemikiller
-insert witty saying here-
Hemikiller's Avatar
United States, CT, Killingworth
Joined Dec 2005
It took a hard knock on the vertical fin and the tail post cracked. No strength in that area until the horizontal is epoxied in place. A fix is as simple as the the same epoxy you'd use to install the horizontal stab. Just be extra careful to get the vertical and horizontals square to each other and to the wing.
Hemikiller is offline Find More Posts by Hemikiller
Old Sep 19, 2013, 03:41 PM
Joined Sep 2013
Yea, theres a post that runs through the fin and up through the fuselage which has been snapped. Im goina completely remove the fin, affix the horizontal stabilizer with epoxy the drill and pin it down, leaving enough pin exposed out the top of the stabilizer so the fin can also be drilled and pinned down too. It can also be pinned at the front.
On a different note,the 5" wing spar doesnt look up to much. I recently but together a 80 black horse were the wing spar provided was 20" long. Quite a difference!!
Anyway, its a nice looking bird.
Old Sep 19, 2013, 05:18 PM
edwin1 is offline
Joined Sep 2003
I watched one fly last weekend and with the yankin and bankin the guy was doing, I'd say that spar joiner held up fine. I havent heard of it being a problem. But that sure does seem short.
Edwin
Old Sep 19, 2013, 09:17 PM
helifann is offline
Joined Dec 2005
I had a hangar9 p40 from that same series, the elevator snapped. The only way to repair was to cut it off the same way yours broke. I put a dowel in for extra strength, epoxied in place and it worked fine, that was 3 years ago. Plane is still flying today!
For Sale H9 Spitfire + TangoUniform Aircraft - Fuel - Airplanes (FS/W) 0 Jun 08, 2013 10:21 AM
Sold H9 Spitfire korky Aircraft - Fuel - Airplanes (FS/W) 1 Jun 02, 2013 08:46 AM
Discussion A beginners road to the H9 Spitfire maxpower Beginner Training Area (Fuel) 16 Apr 05, 2008 06:32 PM
Discussion landing gear on a Spitfire H9 john charles Fuel Warbirds 3 Feb 23, 2008 11:53 PM
For Sale Damaged H9 PTS Mustang fuselage Hoppla! Aircraft - Fuel - Airplanes (FS/W) 0 Feb 20, 2007 12:07 PM
