Old Apr 17, 2013, 11:06 AM
HiddenSky is offline
Find More Posts by HiddenSky
Joined Feb 2013
Noob needs help
I'm planing on building a homemade exoskeleton from scratch, but in order to do so I need some high torque motors. Preferably brushed just to keep the cost low, but I am not sure where to start. I need a motor that can almost assist my leg. A motor that can kinda pull my leg from a creased position to a almost fully extended position. I have almost every thing worked out besides this and one other thing. I have been looking at all kinds of motors, but I'm not sure which ones can handle the weight. Each of my legs weigh approximately 5-6 pounds (I'm 11), I am aware that the amount of turns a motor has usually means more torque, but less rpm and vise versa. Thanks, Nick
HiddenSky is offline Find More Posts by HiddenSky
Old Apr 17, 2013, 08:42 PM
Joined Feb 2013
Anyone? I really need help
Old Apr 19, 2013, 03:19 AM
Roto Rob is online now
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
Most any motor can be made to work with proper mechanics for the motor. How to select the motor depends on many things. Like what sort of performance do you want out of it. For example a costume type suite that really is for cool factor more than anything else. Some other options could be actual assistance, or heavy lifting. Its really hard to compete with normal muscles on any sort of budget.
Once you decide on a performance level then you can get to a motor selection. You would then need to calculate the power needed to move the weight at the desired speed. From their you could look for a motor that suites those requirements. Next would be figuring out if the mechanics could be made for the motor.
Really could get complicated.
Roto Rob is online now Find More Posts by Roto Rob
Help! Complete noob needs help, please. AtGame7 Car Talk 2 Apr 17, 2013 06:43 PM
Discussion Noob in South Central PA area needs help. djhand2 Multirotor Talk 6 Apr 15, 2013 11:41 AM
Help! SOLVED PZ0420 and Lawmate 1.2 1000mw (noob needs help) Bonestockz06 FPV Talk 25 Feb 06, 2013 10:45 PM
Discussion Noob needs a bit of help bubbasanjohn Batteries and Chargers 5 Feb 04, 2013 12:41 PM
Discussion I need help....im a noob doublehorse 9053 battery question BigRob1823 Beginner Training Area (Heli-Electric) 2 Jan 16, 2013 11:51 PM
