Old Mar 30, 2013, 03:18 PM
Icero is offline
Find More Posts by Icero
buy, crash, save...
United States, MS
Joined Feb 2013
Question
spindle for milling help
I'm interested in cnc milling my own aluminum parts for my rc cars. I understand how a mill works and how to build the table and the 3 axis parts, but I don't know which spindle I need. i need to be able to cut 6061 or 7075 aluminum at no more than a quarter inch. I don't need to be able to mill my parts very quickly, so im willing to make alot of passes if necessary. The area I will need to be able to mill will be about 2ft by 2ft, only using about 6in by 6in most of the time..
Thanks for any help.
Icero is offline Find More Posts by Icero
Old Apr 01, 2013, 08:00 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
I am able to cut aluminum plate on my home built CNC using a Hitachi router instead of a spindle. It's slow and I take very small passes, but it cuts perfectly. For production work I would certainly want a spindle.
My machine is a Joes 4x4 that's been highly modified over the years. I'd suggest you also look at VeloxCNC and maybe XZero as well as CNCrouterparts.
Good luck, and let me know if I can be of any assistance.
tom43004 is offline Find More Posts by tom43004
Old Apr 02, 2013, 04:18 PM
Treeline is offline
Find More Posts by Treeline
Joined Oct 2010
The 3-1/4 hp Porter Cable router has pretty much been settled upon as the defacto standard for the low-end of what would be considered "very capable" milling machines. Real spindles can be quite expensive, such as those made by HSD. http://www.hsdusa.com/viewdoc.asp?co_id=453
Once you are set up, you NEED to do some research for proper feed speeds and router speeds with whatever bits you are using. You could have a "perfect" setup but get really bad results if you don't learn about feed and router speeds.
Do a search using the term: "Porter-Cable 75182".
That's the specific part number for the body of the router you need and without the fixed (or plunge) apparatus that you DON'T need because you are going to use it in on a CNC machine gantry.
Different people may tell you different things, but I've been told by more than one person that the PC router works nicely for aluminum if you don't try to hog away a buttload of metal at one time.
Treeline is offline Find More Posts by Treeline
Old Apr 02, 2013, 07:03 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
there is a 800w mill spindle from china i keep eyeing. rumor has it, they take the FCM fast AC and it gets fed to the mill, then rectifiyed back to DC. i keep wondering of you could hack and run off of DC.
search ebay for '800w spindle'
keep in mind you will have to go very slow. end mills are not rated for the high speed rotations of a router. so you cuts will have to be 'easy' on the machine.
just my .02
nemoskull is offline Find More Posts by nemoskull
Old Apr 07, 2013, 11:41 AM
RCWorks is offline
Find More Posts by RCWorks
Wing Cutter
RCWorks's Avatar
United States, OK, Anadarko
Joined Aug 2003
I'm using a VFD and an 80mm spindle motor, air cooled, I don't think I will need water cooling, if I do the VFD stays and I change only the spindle motor and add a pump and bucket... as for water, I think I prefer coolant...
RCWorks is offline Find More Posts by RCWorks
Old Apr 07, 2013, 04:04 PM
Roto Rob is online now
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
I never answered since its such a tough question. The spindle really needs to match the rest of the machine.
A lower rpm spindle is needed for large cutters, and a higher rpm for the small endmills. The frame needs to be rigid for the larger cutters, and be able to move fast for the small ones.
I have been thinking two spindles are nice. Or better is two machines. A regular mill, and the router table.
Roto Rob is online now Find More Posts by Roto Rob
Old Apr 07, 2013, 10:23 PM
RCWorks is offline
Wing Cutter
RCWorks's Avatar
Joined Aug 2003
I have a Mill/Router table and a Harbor Freight Mini Mill (X2).
My Mill/Router is a home made...
The X2 is going though it's "Change of Life"...
The factory 16TPI leadscrew have been changed with 20TPI, this make it more like a real mill with .050" movement per turn vs .062"... Who mills in factions lit 1/16th of an inch?
I have converted it to an air spring and chucked the torsion spring... if the airspring dies I will simply rig a large counter weight.
The bar used to hold the spindle for changing collets and other tools has been replaces with a spring loaded rod that make sure that the rod can not be left in the machine and turn on...
Next is a set of tramming adjustment screws and an 18"x4"x.75" piece of metal places on the back of the column to keep it from flexing... The big washer does not keep the column as ridged as it needs to be.
The X2 is not a bad machine after you take it apart and makes a few changes and do a proper assembly of it... Think of the X2 as a kit not a ready to use mill... a little work on it pay off in the quality of the products... Later on I will be making some more mods... Thrust bearings on the leadscrews to reduce backlash.
I was considering making is a CNC mill but I make a fair number of prototype items and I like it better as a manual machine.
Having a production machine and a manual machine is what works for me...
Old Apr 08, 2013, 05:28 PM
Alpha35 is offline
Find More Posts by Alpha35
Joined Feb 2008
Rcworks,
The Fignoggle X2 CNC conversion retains full manual functionality.
http://www.fignoggle.com/plans/cncplans.htm
GeneH
May the mass times acceleration be with you.
Alpha35 is offline Find More Posts by Alpha35
Old Apr 08, 2013, 08:37 PM
RCWorks is offline
Wing Cutter
RCWorks's Avatar
Joined Aug 2003
Originally Posted by Alpha35 View Post
Rcworks,
GeneH
If I was going to convert an X2 for automation it would use ballscrews. They run a bit coarse for manual operation... but they run smooth! I am happy the way I am setup, what I would do next is build a powerfeed for it...
Sold Original Mills .75 diesel motor baldguy Aircraft - Fuel - Engines and Accessories (FS/W) 5 Jan 16, 2013 08:58 AM
Discussion Making a CNC Milling Spindle from an R/C Motor vtdiy Electric Motor Design and Construction 55 Sep 17, 2012 10:36 PM
Discussion Fuel for Mills .75 and 1.3 help please Jiffy Vintage & Old-Timer Designs 20 Jul 01, 2009 02:12 PM
Discussion HELP - removing feather spindle for walker 52 bruceden Mini Helis 0 May 04, 2007 08:20 PM
Question Milling spindle speed for aluminum??? David A Ramsey The Builders Workshop 14 Feb 09, 2007 04:07 PM
