Old Feb 03, 2013, 08:47 PM
kwando is offline
Find More Posts by kwando
Joined Sep 2009
Question
New to the hobby, starting with a Dumas Akula (xpost from SBM)
G'day everyone,
Kwando checking in from Victoria, Australia.
I've had experience in most of the other RC vehicles out there (mainly a car guy, though) and have finally decided to try my hand at submarines.
My first kit will be the Dumas Akula, and it's currently on the way from Rogue Subworks. Kevin has been a great help and very patient with all my questions. Cheers mate!
I've been browsing this forum and various other sites over the past couple of weeks and WOW do some of these subs look great!
Ok, so my aim with this kit is to get it as good looking as I can, and in the water for the least amount of money possible. Fortunately I have a number of existing materials at hand which I can recycle into this project.
Most of my car and heli gear is 2.4ghz which I've read won't work. Fortunately I've got an old Hitec 4ch in 27mhz from my first plane which I should be able to find and get working.
This is the list of materials (that I already own) which I intend to use. Please chime in and tell me if anything is not a good idea.
- Hitec 4ch 27mhz TR/RX
- 2 Standard Hitec servos
- Tamiya rattle can paints for the hull
- Lipo hardcase pack (2s, 5000mah)
Needed to buy:
- Motor and ESC
I've done some research, and although the consensus I've read so far seems to indicate that Brushless systems are a waste of time/money, I've actually found some very decently priced items on hobbyking. As long as I make sure to get a low KV motor (<1000) and an ESC with forward/reverse I should be fine right?
Correct me if I'm wrong, but these are the calculations I'm using to determine which motor to get.
I have a 2S pack = 7.4V. If my aim is to get 5000rpm (as per the Dumas spec motor), I need a 5000/7.4 = 675kV motor. Is this train of thought correct?
I've found these motors so far which may be suitable -
1. http://www.hobbyking.com/hobbyking/stor ... Motor.html (42mm can)
2. http://www.hobbyking.com/hobbyking/stor ... 710kv.html (35mm can)
It'd be great if someone who's already built a Dumas Akula to let me know how much room is in the WTC for the motor so I know what sizes I can get.
Sorry for the long first post. I'm quite excited about being able to experience this aspect of the RC hobby. Expect many more questions to come!
Cheers.
kwando is offline Find More Posts by kwando
Old Feb 06, 2013, 11:30 PM
WingRider05 is offline
Find More Posts by WingRider05
Central Alabama RCShips, Sails
WingRider05's Avatar
United States, AL, Odenville
Joined Feb 2006
There's plenty of room in the WTC. The 12 (edit: thats a 6 volt motor, sorry) volt motor that Dumas recommends for the kit is huge. The problem I had was with the WTC for the battery it's seperate from the WTC containing the motor, servos and ESC. I tried the instructions, no help, finally used silicone as a gasket....goodluck!! Lipos get wet.....they are gone. You will need some weight for ballast as well.....
Post pics of your build
Jared
WingRider05 is offline Find More Posts by WingRider05
Old Feb 07, 2013, 05:49 PM
kwando is offline
Joined Sep 2009
Hey Jared,
Thanks for your response.
Good to know about the size of the Dumas motor. I bit the bullet last night and went ahead with the 710kv hobbyking motor.
The lipo pack I intend to use is a hardcase, so maybe if I seal the seems with silicone it'll add an extra layer of waterproofing protection inside the battery WTC.
Can't wait till I can begin the build (still waiting for the kit to arrive). Will definitely post progress pics.
Discussion New to hobby, first post, looking for place to start lardo5150 Beginner Training Area (Aircraft-Electric) 36 Mar 15, 2013 03:50 PM
Question Dumas Akula power setup fly4fun6719 Submarines 2 Jan 22, 2013 03:02 PM
Sold Brand new Dumas Akula Submarine kit shschon Boats (FS/W) 0 Aug 24, 2012 02:50 AM
Dumas Akula Motor Mounting tim_s Submarines 2 Jun 17, 2004 07:20 AM
