Old Apr 22, 2012, 06:23 PM
tailsld is offline
Find More Posts by tailsld
United States, NY, Hamburg
Joined Aug 2011
Way to go mud man....sounds like you have a keeper ..
we are under a winter sorm watch here? I am so moving.....
Yeah Merrill is awesome at his tech responces..
rick
tailsld is offline Find More Posts by tailsld
Old Apr 22, 2012, 06:41 PM
alstrahm is offline
Find More Posts by alstrahm
AMA 3959
alstrahm's Avatar
United States, CA, San Jose
Joined Oct 2002
Originally Posted by concreteman View Post
Hey all! Merrill did fly my Oculus today. He flew it and flew it and flew it....I will say it went just as I expected, Merrill and Target hmmmning and hawwwing over my work. I know it is not to their standards, they build really well, I build really average-with an emphasis on durability. My plane is straight, flew straight out of my hands, and took hard pulls from our Black Widow winch. Once the Oculus was launched it was real apparent this plane totally wants to fly. We had decent air at our field and I landed because I wanted to launch again, not because I couldnt locate or work the good air. I handed my transmitter to Merrill on the second flight, he was totally stoked, and the big grin on his face says he was satisfied by my Oculus' flight qualities. Same thing for Target, he had the Oculus way up there, and next thing I see is barrel rolls, loop festivals, and then he decides to do thermal duty inverted- he is such a ham... Its funny when a plane performs as well as my Oculus, they kind of forget that it wasnt as pretty as some "top caliber" builders models...It is performance that really matters, and durability, you do have to finish the day to reach the podium...the Oculus performs, and the construction is up to the task.
So, let me fire off some thoughts about building the Oculus, while it is fresh on my mind. Like I said earlier, I am not a premier builder, I'll call my skills average, but I can read plans, and follow instructions (well sort of, you can read about that elsewhere). I'll start with the Oculus kit in overall fashion, but in pieces. The fuselage is very nice (Target says it is really well designed, but I dont know why-whatever), and feels stiff enough, but isnt very heavy (my Oculus is #18). The pushrods come preinstalled, and there is a fuse tray included. The wing parts: the rib sheets are way nice, and I totally dig the idea of having tabs on the ribs to keep everything flat (worked for me- and I am the king of crooked!), the spars (center panel and tip panel) are beastly units (when the world ends, those joiners will still be intact) and the wing joiners fit perfectly (thanks for that, Merrill). Merrill uses solid carbon fiber trailing edges and tubular carbon leading edges, nice and strong. In the parts kit are couplers with clevis's, wire connection parts for joining the wing to the center panel, magnets for holding down the spoilers, a towhook, etc. Totally cool.
Building the plane. I got totally lucky, and my schedule cleared (cursed rain, ruined my concrete pours-really, I am a concrete man), so I was able to dedicate some serious time to building. I totally followed the instructions ( well, I tried to anyway ) and started on the wings. The ribs came off the sheet perfectly, and onto the spar, beautiful. Leading edge,trailing edge... all parts centered, glue... I totally blazed thru these parts in record time. Outer panels, same thing, ribs off the sheet, onto the spar, centered, trailing edge-leading edge, squared glued.. damn Im fast. Its even straight! And flat! Tip panels, same thing... Concretemans tip#1, I shaped and sanded down my tip before I glued the tip panel to the mid panel, as I thought I would do harm to something else while working on shaping the tip-worked for me, your mileage may vary. Allrighty then, the wing is built, lets see how it looks put together. Clunk! Hmmm, nowhere in the instructions is when to put angle into the outer rib, so when the panels slide together with the joiner, they mate. Did that make sense? PM Merrill. What the....is going on here. He told me I have to sand the angle into the outside rib, then cap with ply, its on the plans... so I did, situation handled. I may have known this if I built more often, but... Capping the ribs: I got a first hand view of Merrill capping a rib. I tried it like that, and glued my fingers together, and to the rib cap, and it was glued to the rib, awesome, and I could hear the "Benny Hill" song playing while I tore the cap from the rib, then the cap from my fingers and then I got fingers separated. Yeah it was funny... you've done it too... I actually got a nice system going, and it went real well- once I got the rhythm... Lets move to the stabs. The very first sentence says to make sure you have the tapered ends of the spar facing each other, well at least I got one of them. I must say I got distracted by a good song and used them for drumsticks, then threw them down and built the stabs. the building went great, ribs from the rib sheet, trailing edge, leading edge, centered my parts... boom, done. Cool. Let me put them together. Hmm, the rod wont go in one side... uh....doh! I am so lame....I can fix it....I am not going to tell you how I fixed it, unless you do the same thing...please dont. Rudder duty: follow instructions, thought I'd be smart and tape the rudder post to the fuse and shape it real nice- worked great. Put rudder post on plans, followed instructions, built rudder, shaped sanded ready for rib capping. Let me see how it looks on the plane, I built the rudder with the post upside down, are you kidding me???? I am king of dorks....I can fix it. I did a slick job of remove/repair, and it turned out really nice. I am satisfied. Hooking up the bellcrank for the elevator is well thought out and my elevator feels very "connected", and the centering is perfect. I am using MKS DS6100 for the spoilers and rudder, with a Hitec 5085 for the elevator. The servo tray is typical, and works perfect. Covering: hmmmm, I kind of remember me being pretty good with an iron, well I have 2 irons anyway... I totally didnt read the instructions, and used very lightweight covering on the entire wing, rudder, and stabs. Time will tell how much abuse this covering can take. Merrill recommended Ultracote, and I totally blew it on this one...oh well. I also painted the fuse, simply because I dont see white well in the sky....yes, its yellow.
Follow the instructions regarding the CG, Merrill flew mine and said he wouldnt change a thing, cool.
Things that deserve pointing out. Merrill answers PM's and cares about his work, and the customers satisfaction. Make sure you read the instructions first, and highlight the stuff that is printed in bold, it is that way for a reason! This kit is a great value for the cost.
Did I mention how good it flies?It fiies great! Nice job, Merrill!
WD
so WD leaves us 2 word posts, and then comes out with this Great job! looks like me and T are next up!
Al
alstrahm is offline Find More Posts by alstrahm
Old Apr 22, 2012, 07:18 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Yeah, how about a "paragraph break" here and there?!
R,
Target, with more pics of WD's beast
target is offline Find More Posts by target
Old Apr 22, 2012, 08:03 PM
onethermal is offline
Find More Posts by onethermal
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
R,
Hey Target
We are not English majors here, you are just lucky that you got to read more than a 2 word post. A slab of concrete doesn't care how many words someone can type.
Clarence
onethermal is offline Find More Posts by onethermal
Old Apr 22, 2012, 10:18 PM
concreteman is online now
Find More Posts by concreteman
concreteman's Avatar
United States, CA, Torrance
Joined Aug 2004
My punctuation is poor? My spelling is good, and I tell it how it is. My concrete is smooth.
concreteman is online now Find More Posts by concreteman
Old Apr 22, 2012, 10:20 PM
Mr B.... is online now
Find More Posts by Mr B....
Mfg of the Marauder & Oculus!
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
Did I mention how good it flies?It flies great! Nice job, Merrill!
WD
WOW! And I was proud to be part of this!
Concreteman you Rock!
Merrill
Mr B.... is online now Find More Posts by Mr B....
Old Apr 22, 2012, 11:30 PM
stoked6.0 is offline
Find More Posts by stoked6.0
They call me Maj. Sink!
stoked6.0's Avatar
Paso Robles, Ca
Joined Nov 2008
H
WD
I don't have an Oculus, but I do have a Marauder and have had a few conversations with Merrill both on the phone and through email. His service is second to none! His plane are pretty good too .
Sorry I didn't make it to the Fresno classic guys, I hear there were a few wandering around wondering where the beer was. I just was given this pic., it explains it all! Hopefully for Fall Fest...
Forest
stoked6.0 is offline Find More Posts by stoked6.0
Old Apr 23, 2012, 06:59 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I was distraught and confused, all at once.....
It would have been great to see you, Forest. Hope to see you next time in October!
R,
Target
Old Apr 23, 2012, 08:28 AM
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
Yep that sounds right for me...now if I could get 129,000 lbs of truck and trailers to ride smooth.
Clarence
Old Apr 26, 2012, 12:11 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Ordered my covering from Horizon Hobbies website on Sunday night; it arrived at my house Tuesday!
R,
Target
Old Apr 26, 2012, 02:50 PM
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
So "GET IT DONE"
Old Apr 26, 2012, 04:44 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Unfortunately, prodding won't speed up the production. I can only work on it when I'm not away from home.
Old Apr 26, 2012, 05:44 PM
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
I know how that is...in two weeks it looks like I will be spending two weeks in central northern nevada and I might get 2 days at home.
Clarence
Old Apr 26, 2012, 08:20 PM
fearfactorfred is offline
Find More Posts by fearfactorfred
fearfactorfred's Avatar
Nipomo, Ca.
Joined Mar 2007
Nice job WD!!! Way to pump her out!! Laid it down real nice just how I like it. Really enjoyed following your build. Makes me want to build one too now!!! Rock on dude!!
fearfactorfred is offline Find More Posts by fearfactorfred
Old Apr 26, 2012, 08:54 PM
Joined Aug 2004
Fred, you should have heard me (or maybe not!)when I put the rudder on the plane, and saw how well I built it-with the rudder post upside down.... I think they build fast, easy, and they fly great...is there more?
WD
