Old Jan 11, 2012, 04:17 PM
k0mputer is offline
Find More Posts by k0mputer
Joined Jan 2011
Originally Posted by markus123456 View Post
You need a pair. A cloverleaf on the transmitter and skew planar wheel on the receiver usually works best.
Markus
Hey there, cool thanks. Where can I get the skew planar wheel for 5.8 though? I googled it, no sellers found.
k0mputer is offline Find More Posts by k0mputer
Old Jan 11, 2012, 04:42 PM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Alex sells them:
http://videoaerialsystems.com/
So does Hugo
http://www.truerc.net/canada/
I make them upon request, but I currently have a too big backlog to help you out unless you like to wait.
Markus
markus123456 is offline Find More Posts by markus123456
Old Jan 11, 2012, 04:47 PM
k0mputer is offline
Joined Jan 2011
Alex sells them:
So does Hugo
Markus
I've seen that site http://videoaerialsystems.com/ but no option to add product to cart.
For http://www.truerc.net/canada/, they had the wind mill for 5.8. Is that the same as the skew planar wheel?
Old Jan 11, 2012, 05:18 PM
Registered FPVer :)
Joined Aug 2006
The windmill is not the same, but they work the same. In a sense they are interchangeable (Hugo forgive me)!
I've seen on the webpage that they are "on vacation", maybe you have to wait for some days more, but again, Hugo's antennas work equally well.
Markus
Old Jan 12, 2012, 09:03 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I will second the work of Hugo (www.truerc.net/canada). His work is exceptional which is why he and I design together. All of our products are compatible. The True Wire windmill/fan combination will do the same as my BluBeam set and both are compatible with eachother. You can get my BluBeams from here: http://www.readymaderc.com/store/ind...roducts_id=550 I know he's out of stock, but I am sending him a shipemnt this afternoon so he'll be back in stock in no time
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Jan 12, 2012, 09:37 AM
k0mputer is offline
Joined Jan 2011
Thanks for all the good information. So for a 5.8, I can get the cloverleaf for the TX and make the SKP for now, which is my first time, so I could mess it up. Should I just get the Bluebeams Alex mentioned?
-Alex
Old Jan 12, 2012, 10:16 AM
Zen09 is offline
Find More Posts by Zen09
Zen09's Avatar
Germany, HB, Bremen
Joined Jun 2010
Finished my first SPW, for 1180MHz. I've made it from 1mm steel wire.
Now I have to test it with the CL against stock antennas.
I'll keep it in a foam box (raw foam melt and cut to fit the antenna) to protect during transport. I think I'll keep it during running as well, the foam shouldn't affect it much would it.
Zen09 is offline Find More Posts by Zen09
Old Jan 12, 2012, 01:55 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^ Wow! That is some nice work there. You will really like your new antenna system.
-Alex
Old Jan 15, 2012, 08:58 AM
Vertige is offline
Find More Posts by Vertige
France
France, PACA, Antibes
Joined Jan 2012
Hi everybody, I’m new to the forum, I do practice FPV with a Multirotor MK, in France, I have been reading your post here on antennas from A to Z, and I have found it fascinating.
I did create, thanks to yours informations, my Pinwheel and Cloverleaf antennas and they do work unbelievable (only itch is: to be careful the way you land not to make a pancake out of it)…
My question: how important is the length of the feed point, should it change with frequency, does it change impedance, does it matter at all?
Second question: should the length of the lobes of the Cloverleaf (for a pair of matching antennas) be longer than those of the Pinwheel?? (I have found contradictory opinions on the matter)
Vertige is offline Find More Posts by Vertige
Old Jan 15, 2012, 02:03 PM
Registered FPVer :)
Joined Aug 2006
Originally Posted by Vertige View Post
Hi everybody, Iím new to the forum, I do practice FPV with a Multirotor MK, in France, I have been reading your post here on antennas from A to Z, and I have found it fascinating.
I did create, thanks to yours informations, my Pinwheel and Cloverleaf antennas and they do work unbelievable (only itch is: to be careful the way you land not to make a pancake out of it)Ö
Second question: should the length of the lobes of the Cloverleaf (for a pairs of matching antennas) be longer than those of the Pinwheel?? (I have found contradictory opinions on the matter)
Mike,
Yes, keep the feedpoint as short as possible and yes, the CL lobes should be about 2 - 3% longer than the lengt of the SPW.
Markus
Old Jan 15, 2012, 02:59 PM
Vertige is offline
France
Joined Jan 2012
Mike,
Markus
Thanks Markus for the info.
Old Jan 20, 2012, 10:34 PM
thehaw24 is offline
Find More Posts by thehaw24
thehaw24's Avatar
United States, CA, Hesperia
Joined Dec 2011
Does anyone know where i can purchase the Cable to build this antenna? Home depot,radio shack, Im not trying to order online.
thehaw24 is offline Find More Posts by thehaw24
Old Jan 20, 2012, 10:41 PM
k0mputer is offline
Joined Jan 2011
Home Depot
Old Jan 21, 2012, 01:06 PM
thehaw24 is offline
thehaw24's Avatar
Joined Dec 2011
Home Depot
What is it called, Im looking for the cable not the copper coated wire..
Old Jan 21, 2012, 09:30 PM
rubenhak is offline
Find More Posts by rubenhak
Joined May 2009
Hi Guys, I'm very new to FPV. Sorry if this question was already asked 1000s of times and also answered that much I just cant find the answer.
I've got Fat Shark Predator RTF FPV Headset System 5.8GHz. It comes with 100mW transmitter and 3dBi antenna. If anybody use it, how far is the operation range of this system?
How much is Skew-planar wheel antenna capable to extend the range?
Ruben
rubenhak is offline Find More Posts by rubenhak
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 53 Feb 21, 2015 07:02 PM
Mini-HowTo DIY Ground Plane omni directional RX antenna IBCrazy FPV Talk 60 Nov 19, 2012 06:11 AM
Discussion 900 mhz circular polarized antenna? g00bd0g FPV Talk 9 Aug 21, 2012 09:54 AM
Discussion 18dbi Circular Polarized Patch ? Coyote64 FPV Talk 3 Nov 10, 2010 04:59 PM
Question Circular polarized antenna question Sov4life FPV Talk 8 Mar 05, 2010 05:00 PM
