Old Nov 19, 2009, 01:18 PM
grfcon is offline
Find More Posts by grfcon
chronic in training
grfcon's Avatar
L.A. beautiful san fernando valley
Joined Nov 2008
Question
twin motor 2 battery setup question.
okay 2 lipos... parallel into a single double male sides connector..then split back out to each speed controller. (see attached figure) Or can I solder the two batts onto the 12 gauge high wind wire ( or whatever it is called) and just use wire instead of the connector in my drawing? let me know thank you.
Gary
grfcon is offline Find More Posts by grfcon
Old Nov 20, 2009, 12:12 PM
matwelli is offline
Find More Posts by matwelli
1400 watt RW Zephyr
matwelli's Avatar
Taranaki New Zealand
Joined Sep 2003
Hey Man, I would do away with the deans in the middle, just more resistance/failure point and it serves no real purpose, unless you want a single point to be able to disconect both batts at once
matwelli is offline Find More Posts by matwelli
Old Nov 20, 2009, 12:13 PM
grfcon is offline
chronic in training
grfcon's Avatar
Joined Nov 2008
thanks was thinking the same
Old Nov 20, 2009, 08:54 PM
blanik213 is offline
Find More Posts by blanik213
BLANIK213
blanik213's Avatar
United States, NY, Phoenicia
Joined Feb 2008
Why not just use one battery split out by a customized connector into the two esc's. I am running my high powered twin motor system that way because it simplifies connector's as well as locating and securing the the battery the only reason that I would run two batteries would be to achieve a desired mha output that was unavailable as a single battery.It also saves weight(less wire). Just my thoughts.
blanik213 is offline Find More Posts by blanik213
Old Dec 04, 2009, 02:45 PM
grfcon is offline
chronic in training
grfcon's Avatar
Joined Nov 2008
thanks... already had a pair of batts... plus I needed the weight... though If I didn't need the weigth I totally agree with your idea
Discussion Wire question for twin brushless setup whatala Electric Plane Talk 21 Oct 17, 2009 08:21 AM
Discussion Twin Motor setup for a beginner's build Ricky401 Electric Plane Talk 6 Oct 15, 2009 02:48 AM
Discussion electric twin motor setup questions grfcon Flying Wings 2 Oct 03, 2009 02:18 PM
Discussion Twin motor question kaging Electric Plane Talk 23 Sep 24, 2009 04:28 AM
Twin Motor Setup Question (2 Diodes) fossil Power Systems 5 Aug 27, 2002 03:41 AM
