Old Oct 03, 2007, 07:11 AM
zakstang's Avatar
Joined May 2005
magpie AP wing on SS question...
those of you that use the magpie AP wing on your SS....what did you gain by doing that if anything?? thinking about it but am wondering what the advantages are..???does it fly slower? can it carry more payload??? thx for your input...
zakstang is offline Find More Posts by zakstang
Old Oct 03, 2007, 12:56 PM
I AP'd myself again......
aviatordave's Avatar
Yawn....Iowa
Joined Mar 2005
It stays in the air longer, less drag. Wing area is about the same, but you use less battery to get where you need to go. It lands faster, but not that fast as it is quite manageable. I use this combination all the time as the magpie fuse seemed to weathervane into the wind to much. You can prob get twice the flight time out of a charge with the magpie wing.
Dave
aviatordave is offline Find More Posts by aviatordave
Old Oct 03, 2007, 01:51 PM
AutoQuad OS developer
maximal's Avatar
near Ithaca, NY, US
Joined Aug 2004
What Dave said, plus it can handle wind much better than the stock wing. Having tried both, I personally prefer the Steven's Aero balsa SoarStick wing, which is a similar in size to the Magpie AP wing, but includes ailerons/flaps and is very light (~5oz with HS-55 servos, a carbon fiber leading edge, and a SolarFilm covering which is heavier than SoLite). With both the replacement wings I've found better handling when using 2 "front" wing mounts from the SS kit, vs. using the shorter rear wing mount-- seems to keep the wing more parallel to the fuse.
Cheers,
-Max
maximal is offline Find More Posts by maximal
Old Oct 03, 2007, 06:51 PM
zakstang's Avatar
Joined May 2005
thx ordering one tonight...
Q's about mounting alternate wing on SS der Oberflügel Parkflyers 1 Jul 01, 2005 02:32 PM
Piece O cake wing on SS for AP FlybyPDX Aerial Photography 12 May 25, 2005 11:48 PM
Spring AP with MagpieAP wing on SS fuse maximal Aerial Photography 2 May 20, 2005 01:25 AM
How about Twinstar wing on SS worzul Aerial Photography 0 May 01, 2005 04:11 PM
Himax on SS Question craab Power Systems 1 Jun 21, 2004 11:23 AM
