Old Jun 14, 2007, 03:08 PM
Lonewolf172
USA, IN, Noblesville
Joined Dec 2004
HELP: Scroll Saw question
Im sorry, I know this probably isn't the right place to ask this but I have tried Sears with no replies. I have a Craftsman 16" scroll Saw. Is the some trick or do I need an additional adapter to install the plain end Sprial blades. These blades have a slight twist at each end and when I try to install them they either bend out of shape or slip off the set screw.
lonewolf172 is offline Find More Posts by lonewolf172
Old Jun 14, 2007, 06:41 PM
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
its not the T pin type ends on the saw itself?
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Jun 14, 2007, 08:10 PM
Lonewolf172
Joined Dec 2004
Blades
No. The saw itself accepts both pinned and plain end blades. the problem I think is 1) the slight twist in the blade itself and 2) the blades arent as wide as a plain end blade.
Old Jun 14, 2007, 11:25 PM
St. Mary, Maryland, United States
Joined Dec 1996
That is tricky. The rod blades kinda work OK in mind but you have to catch it just right - I have the thumbscrew type clamp where it is a knob molded on to a fairly wide bolt. A set screw would be tougher. Maybe grind the end of the setscrew flatter? Or cut a 1/4" square piece of K&S brass shim stock to fit between the blade and the setscrew.
Chris True is offline Find More Posts by Chris True
Old Jun 15, 2007, 01:23 AM
scratchandbash's Avatar
Grove City PA basement/park
Joined Feb 2005
Nah, that's not out of place at all.
...but I was hoping it would be something like the question a guy sent into Hot Rod magazine, asking if he could mount a Hoover on top of his carb, for a blower.
Bill
scratchandbash is offline Find More Posts by scratchandbash
Old Jun 15, 2007, 08:33 AM
Lonewolf172
Joined Dec 2004
Blades
Thanks Chris. I might give your idea a try.
Yippee! Help finding a scroll saw happymac555 The Builders Workshop 25 Feb 14, 2005 12:50 PM
Help!! - Video Card Question? mrebman Life, The Universe, and Politics 13 Mar 02, 2002 04:08 PM
HELP,, Minx Intake question JasonJ Electric Ducted Fan Jet Talk 1 Dec 29, 2001 02:48 AM
BEST BUY on scroll saw temacc Electric Plane Talk 14 Dec 02, 2001 06:34 PM
Help with a Teddy Question Michael Heer Foamies (Kits) 5 Sep 10, 2001 09:20 AM
