Old Jun 26, 2004, 12:38 PM
SoCal
Joined Jun 2002
Alfa Mig-15 Brushless questions...
I just ordered the Alfa Mig and have a couple questions about the power system...? I have an extra Astro 020 803 motor setup - will this work in this jet -and- can I use my 8 cell Nimh 1800 batteries instead of the liPoly...?
Does the belly need to be glassed or covered for ROG like in the videos...?
chrisw is offline Find More Posts by chrisw
Old Jun 26, 2004, 12:47 PM
dave morris's Avatar
orlando fl
Joined Oct 2000
Both the motor and the cells would be to heavy, better stick with what is recommended.
dave morris is offline Find More Posts by dave morris
Old Jun 26, 2004, 12:59 PM
SoCal
Joined Jun 2002
If the Astros too heavy can someone suggest another motor since HL is currently out of stock on their recommended motor for the Alfa Mig...
Figures the motors out of stock....
-Chris
Old Jun 26, 2004, 03:18 PM
TN
Joined May 2000
Hey guys
Chris asked:
No, the bottom of the model is covered with a formed styrene shell that protects it against abrasion.
Chris:
You could always buy the MP Jet 25/25-26 Mk2 in the 5:1 gearbox and remove the motor. I did that on the first one that I built. To remove the motor you remove the three screws from the gear housing, this gives you access to the 3 small screws that attach the motor to the gearbox. You also have to pull the pinion from the motor shaft.
A bit of a pain, but a possible solution.
Mike Hines
Hiflyer is offline Find More Posts by Hiflyer
Old Jun 26, 2004, 03:24 PM
TN
Joined May 2000
Hey
Just thought of another possible solution. Also listed by Alfa as a motor for the Mig is the Model Motors "Mini AC 1215/12 (HL Part# PM512). The Kv of this motor is a bit higher than the MP Jet, but all of the other recommendations should hold up.
Mike Hines
Discussion Alfa mig-15 questions Airplane boy Electric Warbirds 13 Nov 26, 2006 07:36 PM
Sold Alfa Models Mig-15 Brushless superxtra Aircraft - Electric - Airplanes (FS/W) 9 Sep 21, 2005 11:51 PM
Alfa Warbirds and Mig 15 Brushless Combos realdeal Aircraft - Electric - Airplanes (FS/W) 1 Nov 01, 2004 11:24 AM
Holy cow that Alfa Mig 15 looks SWEET akeyzoo Parkflyers 22 Apr 24, 2004 12:02 AM
Question Wattage Mig 15 and brushless motors Krason Power Systems 1 Oct 30, 2003 05:26 PM
