Old Jan 29, 2014, 05:41 PM
Customer Support
Nancy BH CSR's Avatar
United States, CA, Irwindale
Joined Nov 2010
Yippee!
BlitzRCWorks NX3 3-Axis Airplane Gyro
Good afternoon Pilots!
We recently received a new shipment of Gyros.
Please welcome the BlitzRCWorks NX3 3-Axis Airplane Gyro.
It supports 4 model types, which are Single Aileron, Dual Ailerons (Flaperons), Delta-Wing, and V-Tail. The Flight Modes that it supports are the Standard / Rate Mode for stabilization, Hold Mode for calibration, and Off Mode so you can have total control of the aircraft using the transmitter. You're looking at a 40mm x 25mm 3-Axis Gyro that can be configured to a comfortable or more senstive send of control depending on your own preference.
Obtain one now at http://www.bananahobby.com/blitzrcwo...lane-gyro.html.
Nancy BH CSR is offline Find More Posts by Nancy BH CSR
Old Mar 04, 2014, 01:37 AM
Joined Apr 2012
nx3 gyro
I have just ordered this for my Skysurfer Pro. Any comments yet from anyone?
gusscott is offline Find More Posts by gusscott
Old Mar 04, 2014, 03:12 PM
BHCSR ALEX's Avatar
Joined Mar 2014
NX3 Gyro Video
Hello gusscott!
The NX3 Gyro is amazing in flight and easy to use! I was able to test it out and use it in flight with different aircraft, and it does a fantastic job at keeping the unit stable in the air. An instructional video will be coming very soon!
BHCSR ALEX is offline Find More Posts by BHCSR ALEX
Old Mar 07, 2014, 01:26 PM
BHCSR ALEX's Avatar
Joined Mar 2014
NX3 Review Video is LIVE!
gusscott, the NX3 review video is now live! I suggest checking it out if you need some assistance with the setup procedure.
I have linked it below:
NX3 Gyro Review feat. Knight 860 & Sky Surfer V.5 (33 min 18 sec)
Old Jun 23, 2014, 09:42 PM
United States, PA, Lititz
Joined Jan 2014
very nice gyro. I really want one. Anybody use theres yet if so how did they work
kwebersole is online now Find More Posts by kwebersole
Old Jun 24, 2014, 02:08 PM
BHCSR ALEX's Avatar
Joined Mar 2014
Hello kwebersole!
I apologize if you were looking for opinions from others, but I would like to add on a few details. Currently we carry two gyro systems, the NX3 3-axis Gyro and the BS2X 2-axis Gyro. Out of the two, the NX3 is by far the easiest to use and also the one with additional features such as the extra axis. On an airplane it will aid with the longitudinal, lateral and vertical axis.
You are able to dial-in how much you would like for the gyro to assist you during flight. This is done through a set of dial pods and depending on your preference, you can make it out to be very subtle or more involved with the corrections during the flight. I would not recommend applying too much correctional input or the gyro may over compensate which can be an issue during flight. If you have an adequate radio system, you also have the option to turn it off or on during flight.
The overall flight performance of the NX3 was great, I was able to easily tell the difference when it was shut off and back on. The wind conditions were manageable during the times that I flew, but the NX3 made it even better and provided some peace of mind with the extra stability. It's a very nice system to have, especially if you are trying to learn new things you are not comfortable with but plan on doing in the future without the gyro. Hope this helps!
All the best,
Alex
Old Feb 15, 2015, 02:08 AM
scouv's Avatar
United States, CA, Santa Barbara
Joined Nov 2010
What batteries are people running.
I was planning to use a 4 cell aaa pack. This may be a no go. Any suggestions
Are NIMH an option? Will a 2s lipo at 7.4 V exceed the voltage range of 5 to 6 volts?
scouv is online now Find More Posts by scouv
Old Feb 16, 2015, 01:20 PM
BHCSR ALEX's Avatar
Joined Mar 2014
scouv,
Are you referring to a separate battery pack for the receiver or the gyro? The gyro won't require a separate battery pack since it will be powered by the receiver. If you are looking for a separate battery pack to use with your receiver, I suggest checking with what it calls for. Its common to see receivers operate between 4.8V-6V, but there's some that operate at 7.4V too.
-Alex
Old Feb 18, 2015, 12:23 AM
scouv's Avatar
Joined Nov 2010
The package insert reads:
"Specifications:
1. Voltage Range:5-6V DC. (Do not use dry cell batteries!) "
Does this mean NIMH are a no go?
Old Feb 18, 2015, 12:33 PM
BHCSR ALEX's Avatar
Joined Mar 2014
scouv,
Thank you for the clarification, good point out. I believe that bit of information is explaining to avoid the use of external battery packs, while stating the operating voltage range. You wont need an external power supply for the gyro since the receiver will be powering it on. Usually the external power source or BEC is connected to the receiver, so that wont be needed on the gyro.
-Alex
Sold *PRISTINE* BeastX Microbeast 3-axis Gyro System - Version 3.0 ShaneXman Aircraft - General - Radio Equipment (FS/W) 1 Jan 09, 2014 09:51 PM
Sold HobbyPartz 3 axis airplane gyro Terkan Aircraft - General - Radio Equipment (FS/W) 1 Nov 06, 2013 08:09 PM
Question Multi Blade helis....regular gyro or 3 axis gyro Maduro Mini Helis 4 Oct 29, 2013 01:04 PM
Sold Futaba CGY750 GYRO, 3-Axis Gyro & Governor for sale rcedge Aircraft - General - Radio Equipment (FS/W) 1 Oct 20, 2013 11:45 AM
