Old May 18, 2011, 05:50 PM
CF-JUL
julienjj's Avatar
Quebec, Canada
Joined May 2010
Power config for Ultimate biplane 40"
What would you recommend me for powering my new ultimate biplane
specs:
Wing Span: 42 in / 1060 mm
Wing Area: 578 sq in / 37.3 sq dm
Flying Weight: 4.5 lb / 2050 g
Fuselage Length: 39.5 in / 1000 mm
Im not looking for too much sportiveness, i will likely use it for FPV, so I would prefer to have a greater autonomy....4500mah battery ?
I will use a Turnigy Dlux 70A (support 2 to 6s) esc that I already have. I have no idea what to take for the motor /prop. The plane was intended to use a .46glow engine
julienjj is offline Find More Posts by julienjj
Old May 18, 2011, 06:28 PM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Something like this running at 700W-800W (~150W/lb) on 4s might do well (ignore all the typos in the "information"!): http://2dogrc.com/product/dualsky-xm...t-900w-46-size. You'll need to match Kv with desired prop size. For a biplane you probably need a big prop, so get the lowest Kv version of this motor.
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old May 18, 2011, 07:50 PM
CF-JUL
julienjj's Avatar
Quebec, Canada
Joined May 2010
I think a decent prop size could be 12x8, Any chance i can get something equivalent at HK ? like a http://www.hobbyking.com/hobbyking/s...dProduct=14734
Old May 18, 2011, 09:09 PM
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
Why HK? You could take a look at this motor from Hobbypartz. $28
They ship from here in the US. Oh wait, just noticed your in the Great White North. Well anyway, its still not from China. (shipping, not the motor)
If you do look at Hobbypartz, take a look at the Gens Ace batterys. There good for the price.
http://www.hobbypartz.com/monsterpow...ess-motor.html
ScooterInVegas is offline Find More Posts by ScooterInVegas
Old May 19, 2011, 06:42 AM
CF-JUL
julienjj's Avatar
Quebec, Canada
Joined May 2010
I think im gonna be going with the monsterpower, plus its in special this week.
Old May 19, 2011, 09:19 AM
Straight up is all I ask
Fairfield Ct USA
Joined Apr 2002
I would push the cell count up to 5 or your flight time will suffer .
jmolwitz is offline Find More Posts by jmolwitz
Old May 19, 2011, 04:56 PM
FOAMIES ROCK MR. BILL
williamleelewis's Avatar
United States, OH, New Carlisle
Joined Apr 2011
Just a stupid question that I hope someone can answer. If a motor suggestion for power is 4-5 lipos what would a 3S provide? I own a Monster 46 and it suggest 4-5 lipos. I have 2 { 3S - 5000 mAh } lipos that I would like to use on a PT-40 Trainer that weighs 6.75 lbs. I am converting this plane to electric.
THANKZ, William
williamleelewis is offline Find More Posts by williamleelewis
Old May 19, 2011, 06:25 PM
Village Idiot!
Joined Apr 2011
Slower plane. Motor rpm rating is based on voltage. Kv is at one volt. If you go down in battery voltage, you should go UP in Kv OR a higher pitched prop. But a higher pitch prop can mean more amps, which will make for shorter flighs
Old May 22, 2011, 04:22 PM
Joined Apr 2011
So.... I sould be fine. I thought that I would use a 13x8 or 14x8 if I have the ground clearence. I did convert the 3 stage landing gear to a tail dragger system which gave me some more ground clearence. I probly should use a 80A esc ? The motor is EXCeedRC Monster 46 ( 50mm x 55mm / 670kv ). Anybody else with suggestion on my use of 11.1v 5400mAh VENOM Li-Po or my 11.1v 5000mAh ???
  • THANKZ
    William
Old May 22, 2011, 05:05 PM
Former Futaba employee
Joined Aug 2006
I always think of a motor manufactures voltage a maximum and not a minimum. On 3S you will have to swing a bigger prop then on 4-5S
keyman923 is offline Find More Posts by keyman923
Old May 22, 2011, 09:05 PM
Joined Apr 2011
Yea.... what is confusing is when the kv is high on a motor ( ex. 1200kv ) the prop size is small ( 9x5 ) and when you use the same motor size but decrease the kv ( 900 ) you can sling a bigger prop... Confusing to me. And then you throw in the fact of inexperence and this can costly if not sure
Discussion 22" Ultimate Biplane for IPS Power P. Tritle Scale Kit/Scratch Built 165 Jul 14, 2013 04:59 PM
For Sale seagull ultimate biplane with saito 150 Full Spool Aircraft - Fuel - Airplanes (FS/W) 6 Apr 11, 2013 07:50 PM
For Sale Ultrafly Ultimate Biplane ARF Want to trade for nitro engine donho1 Aircraft - Electric - Airplanes (FS/W) 9 Apr 09, 2011 06:09 PM
Sold GP Ultimate Biplane 1.60 RTF LPU iowa city CptnBE20 Aircraft - Fuel - Airplanes (FS/W) 2 Mar 26, 2011 12:41 AM
Article COX Brand Ultimate 40 Biplane .40 size glow ARF Review Mendnwngs Fuel Plane Talk 10 Sep 27, 2006 01:32 PM
