Old Sep 29, 2010, 04:13 AM
KE your cub.
Curare's Avatar
in the gutter, again....
Joined Jun 2005
Cheapest place in aus to buy sanyo nicads?
I'm after some good (sanyo) high capacity sub c's, around the 2300-3000mah range.
I've tried NiMH's and they can't handle the current draw, and it's an enclosed system so lipos are out. Weights not an issue so the old bullet proof nicads are out!
SO, where's cheap?
Curare is online now Find More Posts by Curare
Old Sep 29, 2010, 04:30 AM
knee ligaments are over rated
dingo's Avatar
Melbourne , Outer East .
Joined Dec 2003
I think you`d be lucky to get nicads in that capacity these days . Have you tried GP nimh cells . They were the class leaders & I constantly ran mine above 100 amps in bursts & theyre still ok .
dingo is offline Find More Posts by dingo
Old Sep 29, 2010, 04:37 AM
Electric Hippy
Brisbane
Joined Nov 2005
http://www.flyelectric.com/cellsCPnicad.html
Eagleburger is offline Find More Posts by Eagleburger
Old Sep 29, 2010, 07:27 AM
Joined Jul 2007
Jaycar
Zootster is offline Find More Posts by Zootster
Old Sep 29, 2010, 08:29 AM
Is my CG correct?
discostu956's Avatar
Wollongong, Aus
Joined Sep 2009
Any drill packs going cheap? Most of the cheaper ones of them seem to be nicads, and they seem to handle a fair bit of crap.
So the high discharge NiMH still don't handle the current that nicads will?
discostu956 is offline Find More Posts by discostu956
Old Sep 29, 2010, 07:42 PM
KE your cub.
Curare's Avatar
Joined Jun 2005
The biggest problem with the nimhs is the voltage drop at high amps. What they're going into has voltage sensing, so it notices the drop across the pack, and then decides the pack is stuffed straight off the bat.
Lithium works ok, but the problem with the cells i have is they've all got their own internal hi-lo cutoff circuitry. In a pack situation this is lunacy, as one cell on charge will cut off when peaked, leaving the others to get more than thier fair share, leading to a horribly unbalanced pack, and "death" of a few cells after about 30 cycles.
Hence my reasoning for going back to the auld faithfulls! they may be heavy, and not carry much capacity but you can beat the p*ss out them and they just keep on workin!
Old Sep 30, 2010, 12:08 AM
de-registered abuser
gouch's Avatar
Lake Macquarie, Aust.
Joined Dec 2002
If weight is no issue, and huge current draw is, why not lead acid bike battery? You can get around a 5, 7 or even 14 amp hour that will crank serious amps.
What is it for?
How much do you need to pull? Those GP cells are pretty awesome at feeding big current and holding voltage as Dingo has already mentioned
gouch is offline Find More Posts by gouch
Old Sep 30, 2010, 01:33 AM
KE your cub.
Curare's Avatar
Joined Jun 2005
The problem with using a lead acid pack is that it's only 12v. I need 14.4!
It's for a roomba. The original packs were nicads, and I'm starting to figure out why.
Nimhs are great, until it gets stuck on something and current spikes. It pretty much just shuts down!
Old Sep 30, 2010, 03:58 AM
Gizologist
timbuck's Avatar
gold coast australia
Joined Aug 2008
This site has amazing prices
You buy them in packs 3x 4pack or 5x 4pack no stock ATM but i think there about $59 for 5 packs for 1000mah , they do get 2000+ mah aswell
Tim
http://www.crazysales.com.au/electro...6?show_all=yes
timbuck is online now Find More Posts by timbuck
Latest blog entry: More colours
Old Sep 30, 2010, 04:00 AM
KE your cub.
Curare's Avatar
Joined Jun 2005
errrr.
what site.
Old Sep 30, 2010, 05:52 AM
gouch's Avatar
Joined Dec 2002
Originally Posted by Curare View Post
It's for a roomba.
Lazy bstd
Old Sep 30, 2010, 07:49 PM
KE your cub.
Curare's Avatar
Joined Jun 2005
Originally Posted by gouch View Post
Lazy bstd
If I could figure out how to make it sand balsa and bring me beers, I'd be a happy man.
Till then I'll just have to deal with it only cleaning my floors. Woe is me
Old Sep 30, 2010, 07:57 PM
gouch's Avatar
Joined Dec 2002
2 words: radio control
Old Sep 30, 2010, 08:47 PM
KE your cub.
Curare's Avatar
Joined Jun 2005
hehehe, it comes with it's own remote, so you can steer it, but I'd need to add a 2.4 rx and an arm to get me the beers!
wait, thats not as stupid as it seems..... *devious face*
KE your cub.
Curare's Avatar
Joined Jun 2005
Tim
Sorry mate I didn't see any sub c cells, am I looking in the right spot?
Question Where is the best and Cheapest Place to buy Depron Foam bakon 3D Foamies 2 Aug 31, 2010 09:44 AM
Discussion Where to buy Solder-It or Zinc flux and solder for lipo tabs in Aus?? Ampdraw Australia 3 Aug 16, 2010 05:31 AM
Discussion Cheapest place to buy epp pakrjet or epp plane ARF'S somtimes Foamies (Kits) 2 Apr 13, 2010 10:24 AM
Discussion Cheapest place to buy bell type motors? Razor_Racer Power Systems 9 Oct 31, 2009 06:41 PM
cheapest place to buy sanyo rc2400 batteries. xxcysxx Electric Heli Talk 6 Jun 23, 2004 12:20 PM
