Old Nov 01, 2010, 09:38 AM
phildoubleday is offline
Find More Posts by phildoubleday
phildoubleday's Avatar
Joined Mar 2009
Wing Design
I want to make a flying wing, and wanted to run it by ya'll before I put the razor to foam. Does this look like it'll fly? Any help is appreciated.
phildoubleday is offline Find More Posts by phildoubleday
Old Nov 01, 2010, 11:33 AM
meshyx is offline
Find More Posts by meshyx
meshyx's Avatar
Joined Feb 2010
Looks like it will fly fine, it is a fairly standard "planform" except for the tips.
Angling the tips will provide some slight dihedral/self righting, although you might have less stability in yaw since they aren't very tall.
To explain further, they won't provide much of a corrective force when "flying slightly sideways", which is when regular tip-plates will make sure the plane is pointing the same way it is flying.
How about cheating a bit and putting on some tip plates at the dihedral break? Like this
Well, you could always glue those on later too if you find it is a bit squirrely.
Wings fly okay without tip plates at all, they just wobble a bit more, so try it like your original design first.
EDIT: or maybe try it with low verticals on top, like
meshyx is offline Find More Posts by meshyx
Discussion Delta Wing Design / Scaling mattgatten Flying Wings 6 Mar 04, 2011 01:10 PM
Discussion Easy Glider Wing Design? ForeverFlying Sailplane Talk 18 Dec 01, 2010 03:59 AM
Help! flap design help required for swept wing miniphase Flying Wings 87 Nov 07, 2010 01:53 PM
Discussion strongest wing design Boogie_ The Builders Workshop 11 Oct 22, 2010 11:41 AM
Help! Data Wing Design rimshotcopter Flying Wings 0 Oct 11, 2010 10:32 AM
