Old Dec 22, 2008, 11:17 PM
kylewoody's Avatar
United States, FL, Crestview
Joined Oct 2008
Mirage 2000 EDF question
Hey guys,
I have on order the ARF version of the Hobby Lobby/Nitroplanes/other misc. sellers of the Riccs Mirage - sans TX/RX. I'll be using my 2.4 Ghz.
I understand the stock ESC and battery pack suck, and don't power it well, and have had overheating problems, etc. I was wanting to upgrade these two pieces of equipment.
What do yall think of an E Flite 30amp ESC, and E Flite's 2100 miah 3S pack? Would this work well on the plane? It seems that I would have to shoe-horn the larger E Flite battery pack in, as it's larger than the stock one.
Any recommendations? As well, would all this stuff still work with a standard reciever, and other stock gear?
Thanks!
Kyle
kylewoody is offline Find More Posts by kylewoody
Old Dec 23, 2008, 02:29 AM
X-15 Jockey
burkefj's Avatar
Joined Oct 2006
the 30 amp will probably be fine, the eflite pack may be a bit big, you'll have to see, I run mine with a 2100 thunderpower pack which are about the smallest for the size, you need to cut into the battery bay plastic to connect the two bays and I put my receiver on the bottom of the plane, but once you have done that, you can slide it in without too much trouble. I swapped out the motor for a ls jet screamer, the stock motor was ok but was a heavier inrunner.
Check the servos carefully as well as the mounting and control rods/clevises, I thought the clevises were cheesy, and I had two planes auger in due to servo failures, but that was a year ago, they probably have that fixed now, and hobby lobby took care of me on both occasions.
Frank
burkefj is offline Find More Posts by burkefj
Latest blog entry: A few Rocket glider shots.....
For Sale kamdax mirage 2000 edf dasquriel Aircraft - Electric - Airplanes (FS/W) 5 Apr 14, 2006 03:32 PM
For Sale FS: Kamdax Mirage 2000 EDF Ducted Fan Jet RTF shschon Aircraft - Electric - Airplanes (FS/W) 7 Jul 19, 2005 01:59 PM
Mirage 2000 EDF kit - Kamdax realdeal Aircraft - Electric - Airplanes (FS/W) 4 Jan 30, 2005 08:04 PM
FS @ FL Jets (or nw oh): RT Mirage 2000 EDF foss1997 Aircraft - Electric - Airplanes (FS/W) 0 Feb 16, 2003 03:50 PM
FS/FT RT MIrage 2000 EDF foss1997 Aircraft - Electric - Airplanes (FS/W) 4 Sep 02, 2002 11:10 AM
