This thread is privately moderated by mattyhawk, who may elect to delete unwanted replies.
Old Nov 05, 2013, 08:38 AM
Fill'er Up!
mattyhawk's Avatar
Oxnard, Ca
Joined Oct 2008
Trader Rating: 66
For Sale
12s WEMO 90mm with ARC $150
90mm wemotec fan
Arc 36-75-1.5 motor
Motor heat sink
Entire unit assembled and balanced by Gary from Efflux rc
Setup for 12S operation
3.75kw
11lbs thrust
HET 100a HV Esc
5.5mm leads
Has some leading edge wear on the blades from dirt. Only flown a couple times
$150 shipped CONUS
Paypal ready
mattyhawk is offline Find More Posts by mattyhawk
Old Nov 05, 2013, 10:52 AM
konviser's Avatar
Joined Jul 2013
Trader Rating: 0
R u sure that can handle 12
S, what's the amp put out on this unit. I'm thinking of putting this in my l39 jtm would u sell without esc? I'm local in la county
konviser is online now Find More Posts by konviser
Old Nov 05, 2013, 01:15 PM
FlyBillyFly's Avatar
Rogersville, Mo
Joined Jun 2008
Trader Rating: 178
On 12 cells the 3675-1.5 pulls 83-85A using only 4000mah 25c packs, this will climb to 90A quite easily when using 5000mah 30c or better packs. Your ESC will be ok as long as it is in the intake duct, IE cut a rectangular hole in the duct at least 3 inches in front of the fan, and have the heatsink protruding into the intake, tape it all in place and you should be able to run at 90A or more continuous.
Found this info
Billy
FlyBillyFly is offline Find More Posts by FlyBillyFly
Old Nov 05, 2013, 02:22 PM
United States, MI, Grand Rapids
Joined Jul 2012
Trader Rating: 5
My question is how do you get dirt in the fan other than a crash in to the ground? Flying in a dust storm perhaps?
jaybay7484 is offline Find More Posts by jaybay7484
Old Nov 05, 2013, 04:44 PM
Fill'er Up!
mattyhawk's Avatar
Oxnard, Ca
Joined Oct 2008
Trader Rating: 66
Nope just flying off a sandy runway.
Old Nov 05, 2013, 04:46 PM
Fill'er Up!
mattyhawk's Avatar
Oxnard, Ca
Joined Oct 2008
Trader Rating: 66
Yes, very useable on 12S. This is actually a fairly popular setup for high power 90mm
Sorry, but I need to sell as a package.
Old Nov 05, 2013, 04:47 PM
Fill'er Up!
mattyhawk's Avatar
Oxnard, Ca
Joined Oct 2008
Trader Rating: 66
Found this info
Billy
Thanks for sharing!
Old Nov 05, 2013, 11:42 PM
Lookout For The!Radio Silence.
wingspan100's Avatar
United States, CO, Aurora
Joined Nov 2007
Trader Rating: 10
12S 5000mAh will likely be too heavy for a 90mm sized jet.
Will this run on 10S or 11S?
What jet did you have this in?
wingspan100 is offline Find More Posts by wingspan100
Latest blog entry: I really like this video:
Old Nov 06, 2013, 09:23 AM
Fill'er Up!
mattyhawk's Avatar
Oxnard, Ca
Joined Oct 2008
Trader Rating: 66
It could work on 11S when I looked at fan calc, but it is more in line for 12S. I never ran this in a plane, I only bench tested it. I was going to put it in a Viperjet, but never panned out.
Old Nov 06, 2013, 09:25 AM
Fill'er Up!
mattyhawk's Avatar
Oxnard, Ca
Joined Oct 2008
Trader Rating: 66
Added More Pics in OP
Old Nov 06, 2013, 03:02 PM
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
Trader Rating: 643
Pretty good deal here...plus Matt's a great seller. Surprised it hasn't sold yet, and if I didn't already have a couple very similar setups, I'd be all over it!
Not sure if folks realize how good a deal it is, so here's a price breakdown:
HET 100A HV ESC: $100+shipping new; ~$60-70 RCG prices with light use
Wemo Midi Fan: $60-65+shipping new; $45-55 used RCG price
ARC 36-75-1.5: $140+shipping new; $100-120 RCG price with light use
Heatsink: $5; $5
Balancing/setup from Efflux RC: ~$35-ish?
So, around $340 retail, $210-250 depending where you fall on the "lets make a deal" RCG spektrum, or $150 here. Seems like $60 to $190 in savings, depending on how you look at it...
-Josh
jgalexander is offline Find More Posts by jgalexander
Old Nov 09, 2013, 10:00 PM
United States, VA, Chesapeake
Joined May 2011
Trader Rating: 5
ive have that same setup in a savox l39 flies great on 12 cell 3000 packs throttle manage with full throttle runs 4 1/2 mniutes light setup and powerful cant go wrong...plane weight is 10.5lbs.
ricksmartinez is offline Find More Posts by ricksmartinez
Sold ARC 36-75-1 w/Wemo 90mm fan hole digger Aircraft - Electric - Jets (FS/W) 0 Sep 21, 2013 04:31 PM
Sold ARC 36-75-1 with Wemo Midi Fan 90mm snoshoe62 Aircraft - Electric - Jets (FS/W) 3 May 26, 2012 02:01 PM
For Sale ARC 36/75/1.5&Wemo Pro 90mm fh64_lucky Aircraft - Electric - Jets (FS/W) 0 Jan 18, 2011 03:28 PM
For Sale 90mm Wemo Pro/ARC 36/75/1.5 fh64_lucky Aircraft - Electric - Jets (FS/W) 3 Jan 05, 2011 10:46 PM
Found Wemo 90mm fan and ARC 3665/1 or 3675/1 fh64_lucky Aircraft - Electric - Jets (FS/W) 1 Apr 27, 2010 06:33 PM
