Old Sep 11, 2013, 01:25 PM
I make stuff
cwrr5's Avatar
United States, AZ, Marana
Joined Dec 2011
More Filling and Sanding
Filled more holes in the fiberglass on the fuselage today. Once dry, will be final sanded with 220/400 grit to prep for paint. Got to "carve the pumpkin" next (cutting out hatches & doors)
cwrr5 is offline Find More Posts by cwrr5
Latest blog entry: Citation II
Old Sep 11, 2013, 04:13 PM
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Looking great CWRR!
demondriver is online now Find More Posts by demondriver
Old Sep 11, 2013, 04:17 PM
I make stuff
cwrr5's Avatar
Joined Dec 2011
Thanks dd, wait till you see the gear... I just ordered the shocks-they're gonna be sick!
Old Sep 11, 2013, 09:00 PM
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Looking good cwrr5.
Eric B.
AirX is offline Find More Posts by AirX
Old Sep 12, 2013, 09:36 AM
I make stuff
cwrr5's Avatar
Joined Dec 2011
Thanks Eric!
Old Sep 13, 2013, 09:40 AM
I make stuff
cwrr5's Avatar
Joined Dec 2011
Prep for Cutting Hatches
All the finish sanding is finally done! It's very smooth, fairly shiny, and quite honestly kind of hard to hold onto at this point.
Got the fuselage mostly ready to cut hatches and doors. Used an ultra fine sharpie and straight edge to re-mark the center line, fuse stations, and some of the cut lines around the rear door, top hatch, cockpit, and landing gear mount.
Old Sep 13, 2013, 09:46 AM
I make stuff
cwrr5's Avatar
Joined Dec 2011
More Cut Prep
I used blue painter's tape on both sides of the cut lines, approximately 1/32" from the line, to help protect the surface while cutting. There is a couple of curvy spots that I haven't quite figured out how to do a clean cut on yet. I'll make the majority of the cuts with a dremel and cut-off wheel.
The nose cone and windows will be cut out after these 4 parts are cut & removed.
Old Sep 13, 2013, 10:19 AM
Up-Out-&-Gone
Joined Mar 2007
That's allot of cutting Sir, keep a steady hand!
Old Sep 13, 2013, 10:26 AM
I make stuff
cwrr5's Avatar
Joined Dec 2011
Thank you sir, I'll try!
Old Sep 15, 2013, 11:04 PM
I make stuff
cwrr5's Avatar
Joined Dec 2011
Minor Update
I updated posts #2-#5, and added more pictures to catch up.
Old Sep 15, 2013, 11:10 PM
I make stuff
cwrr5's Avatar
Joined Dec 2011
"Carving the Pumpkin"
On to the messy, noisy, smelly part. I used a dremel and cut-off wheel(s) to cut the four hatch and door openings along the lines I marked out earlier. I also used a combination of x-acto knife and razor saw to get through the really thick foam parts. It pays to go slow as I found out after shattering two perfectly good cut-off wheels.
The cut didn't turn out quite as clean as I had hoped, but I think this will work.
Old Sep 15, 2013, 11:18 PM
I make stuff
cwrr5's Avatar
Joined Dec 2011
Cutting Windows
I cut a window template from lite ply using the three view and photos for reference, then marked the window outlines on the fuselage sides. The windows are cut with the dremel using a carbide grinding bit. As it turns out, the diameter of the dremel bit is the same as the corner radius of the windows. coincidence???
I'll clean up the holes a little more by hand with a small sanding block. Each opening will (eventually) get a vacu-formed plastic window.
Old Sep 16, 2013, 12:44 AM
Up-Out-&-Gone
Joined Mar 2007
Those windows look Great CWRR!
Old Sep 16, 2013, 09:20 AM
I make stuff
cwrr5's Avatar
Joined Dec 2011
Old Sep 16, 2013, 02:08 PM
Up-Out-&-Gone
Joined Mar 2007
Are you going to add clear plastic windows?
Discussion Shorts Skyvan in blue foam Douglas C Foamies (Scratchbuilt) 8 Jul 12, 2008 10:18 AM
Video Maveric Shorts Skyvan 1.6m electric twin GTurbine Electric Plane Talk 2 Dec 21, 2006 05:10 AM
Fokker Dr.1 Triplane 1/12 Scale Beta Build Morb Scratchbuilt Indoor and Micro Models 158 Sep 19, 2004 10:28 PM
Gallery Shorts Skyvan #2 James Frolik Your Plane Photos 2 Jun 11, 2002 02:43 PM
Gallery Shorts Skyvan #1 James Frolik Your Plane Photos 0 Jun 11, 2002 02:37 PM
