Old Jan 10, 2013, 01:39 PM
FloridaFlyBob's Avatar
United States, FL, Fort Myers
Joined Nov 2011
Prop Hole?
I have a Xoar Props 19x10 PJA Series Beechwood Propeller that has a 10 mm hole. I want to but it on a OS gt33 that has a 8mm shaft, Are there bushings or an adpter to use this prop on my OS 33.
FloridaFlyBob is offline Find More Posts by FloridaFlyBob
Old Jan 10, 2013, 01:50 PM
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
on my 50cc rcg, I use masking tape, just make 2 or 3 wraps, untill the prop fits snug! although my 50cc has a 4 bolt pattern!
theoreticaly, the prop washer, and backing plate, actualy hold the prop!
whiskykid is online now Find More Posts by whiskykid
Latest blog entry: great day!
Old Jan 10, 2013, 02:11 PM
Joined Nov 2011
You don't have any problems with prop balance? I did find some 8-10mm reduction bushings from http://www.electricwingman.com/reduc...mm-insert.aspx
Old Jan 10, 2013, 04:32 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
any noticable vibration, goes away at a click or two above idle!
which is the same as all the props before!
Old Jan 11, 2013, 08:05 AM
WCB
NC
Joined Aug 2005
+1 I've done this many times. Works fine.
WCB is offline Find More Posts by WCB
Old Jan 11, 2013, 07:04 PM
Glover
Brady93's Avatar
Joined Jun 2011
+1 I've also done it without any problems.
I only did if five minutes ago on an electric adaptor, but instead of masking tape, i used thread tape that plumbers use to seal pipe leaks etc.. I wrapped it nice and tight and the prop fits nicely.
Brady93 is offline Find More Posts by Brady93
Help! Cowling prop shaft hole enlargement jchtr3a The Builders Workshop 11 Jan 10, 2013 09:52 PM
Help! Fitting props to motors without drilling holes chrherr Foamies (Scratchbuilt) 5 Jan 06, 2013 08:40 AM
Discussion Prop Hole Centering & size question rkenosha Power Systems 5 May 22, 2012 09:12 AM
Discussion Prop hole enlargement kalmon Electric Plane Talk 26 Apr 01, 2012 04:05 PM
