Old Oct 06, 2012, 02:13 PM
Haul ass! Turn left sometimes
MiG-3 Reno Rocket's Avatar
United States, ID, Idaho Falls
Joined May 2011
Question
Correct drill bit for slip fit
Anyone know the correct drill bit to drill a shaft coupler for slip fit on a 5mm motor shaft?
Have looked everywhere, but all I find is a #9 bit is 0.1960". But google measurement says 5mm is 0.19685 and the person whom posted the comments on a different forum says that i#9 bit is 0.1960" is a slip fit for 5mm,
I cant see how 0.1960" is a slip fit on a 0.1968" or 5mm shaft.
Thanks in advance
HydroPilot.....
MiG-3 Reno Rocket is offline Find More Posts by MiG-3 Reno Rocket
Old Oct 06, 2012, 06:41 PM
Joined Jul 2008
Hydro,
Maybe if you heat the coupler up a bit after drilling it, short of that I agree the mathematics simply do not work. Six ten thousandths is a very small difference but its still a difference.
Kcal is offline Find More Posts by Kcal
Old Oct 06, 2012, 08:48 PM
United States, IL, Fox Lake
Joined Jan 2012
You should have no problem using a #9 drill and some polishing to fit something to a 5mm shaft. The fit will probably be better than a 5mm drill bit. To polish after drilling, wrap a small strip of 180 grit emery paper around the end of an allen wrench and work the drilled part over the paper by rolling it across your hand until the desired fit to the shaft is achieved.
motorfixer1 is offline Find More Posts by motorfixer1
Old Oct 07, 2012, 07:20 PM
Joined Jul 2008
Creeping up on your desired measurement is always a good idea.
Old Oct 11, 2012, 02:20 AM
Joined May 2011
You guys are awesome! Thank you very much.
For Sale Drill Baby Drill!!! 25" drill bits for the modeler in 3 sizes!!! unclegeorge Aircraft - General - Miscellaneous (FS/W) 2 Sep 21, 2012 08:31 PM
For Sale Drill Baby Drill!!! 25" drill bits for the modeler in 3 sizes!!! unclegeorge Aircraft - General - Miscellaneous (FS/W) 0 Sep 14, 2012 09:17 AM
For Sale Drill Baby Drill!!! 25" drill bits for the modeler in 3 sizes!!! unclegeorge Aircraft - General - Miscellaneous (FS/W) 0 Sep 07, 2012 04:23 PM
Sold Drill baby Drill with these 25" drill bits for the modeler in 3 sizes!!! unclegeorge Aircraft - General - Miscellaneous (FS/W) 0 Mar 23, 2012 09:08 AM
Sold Drill baby Drill with these 25" drill bits for the modeler in 3 sizes!!! unclegeorge Aircraft - General - Miscellaneous (FS/W) 0 Mar 15, 2012 10:00 PM
