Old Jan 02, 2014, 04:23 PM
United States, NC, Matthews
Joined Dec 2012
Question
Fuel proof and fiberglass
I have a (wait for it wait for it) ARF and before i assemble it i would like to fuel proof and add a little bit of fiberglass cloth to the inside of the firewall area. My question is do i do the fiberglass first and then the fuelproofing or the other way around or are these two things not a good mix?
p3arljam is offline Find More Posts by p3arljam
Old Jan 03, 2014, 02:40 AM
I am actually really slow
SlowBarless's Avatar
Brisbane
Joined Jun 2008
I would probably brush some epoxy in the areas likely to get oily then if you want to further reinforce the area laminate some fiberglass ontop. Best to use a thin laminating epoxy for better penetration into the wood. Although standard 30min epoxy will work okay.
SlowBarless is offline Find More Posts by SlowBarless
Latest blog entry: Carbon Fiber up close
Old Jan 04, 2014, 05:12 PM
Registered DLG addict
NighthawkF-117's Avatar
Minnesota
Joined Jan 2009
Epoxy is fuel proof. You don't need to use fuel proofing over fiberglass.
NighthawkF-117 is offline Find More Posts by NighthawkF-117
Old Jan 05, 2014, 12:26 PM
Canada, ON, Cottam
Joined Jan 2012
Yep, stick on your glass with epoxy or polyester, and your done. Sand it a bit to get the fuzzies off if you want.
aspeed is online now Find More Posts by aspeed
Question Fuel proof clearcoat on bare Solartex? dgliderguy Painting and Finishing Tips 24 Mar 15, 2014 06:25 PM
For Sale SHock ProoF, Water Proof TX case Mike_eee FPV Equipment (FS/W) 2 Nov 28, 2013 02:37 PM
For Sale SHock ProoF, Water Proof TX case Mike_eee Aircraft - General - Radio Equipment (FS/W) 1 Nov 27, 2013 04:12 PM
Question Fuel proof paint pspring Beginner Training Area (Fuel) 16 Oct 22, 2013 09:21 PM
Discussion How fuel proof IS fuel proofer? MCarlton The Builders Workshop 8 May 05, 2009 06:05 PM
