Old May 02, 2013, 03:46 PM
Dpetsel's Avatar
United States, IA, Coralville
Joined Jun 2012
New Build Of Republic Seabee
Grabbed a set of Seabee Plans on the web and decided to convert it to CAD for cutting. Took about 10 hours to draw it out. Sent to AK models for laser cutting. I have done a few mods as I build it. I have a removable wing. I built a box with ply wing spars to support some CF shafts and decided to put a little dihedral in the wings. Still working on a removable cockpit to give access to inner fuse and battery.Here are some pics thus far.
Fuse formers in place on the jig.
A shot to show the jig I built to keep formers square
A shot of the 1/8" stringers pinned in to dry.
Nice and square.....
Glued stringers and trial fit of elevator
Close-up of the wing box that will be removable and nylon screw applied. Test fit for now
Shot of the CF shafts showing dihedral.
Dpetsel is offline Find More Posts by Dpetsel
Old May 02, 2013, 03:55 PM
dusty bible = dirty life
Majortomski's Avatar
Oklahoma City OK USA Where fakts still exist even if they are ignored
Joined Aug 2000
Where do I send my $$$?
NICE looking build. How about some more details; size, power etc?
Majortomski is offline Find More Posts by Majortomski
Old May 02, 2013, 03:56 PM
Lafayette, In
Joined Dec 2003
It looks nice so far.
Just aquired a G&P Seabee kit and starting it .
What size is yours?
Jack
Jack Brewer is offline Find More Posts by Jack Brewer
Old May 02, 2013, 04:01 PM
Dpetsel's Avatar
Joined Jun 2012
Wingspan 54
Length 34
Hope to use a Power 32 or 15
4s 3300 MAH
Those are the parts I am using for the checking weight and CG right now.
It's always subject to change.
Old May 02, 2013, 07:37 PM
71% of the world is runway . .
Bart83's Avatar
Nederland, ZH, Oostvoorne
Joined Jun 2009
Nice work !!
SUBSCRIBED.
Started on a seabee myself . . only digital building right now
Cheers,
Bart
Bart83 is online now Find More Posts by Bart83
Old May 04, 2013, 02:21 PM
Madison, WI
Joined Feb 2004
Subbed!
Fast Freddy is offline Find More Posts by Fast Freddy
Old May 05, 2013, 12:02 AM
USA, NY, Burnt Hills
Joined Aug 2008
Looks Great!
subbed
WinglessB is offline Find More Posts by WinglessB
Old May 05, 2013, 12:20 PM
Dpetsel's Avatar
Joined Jun 2012
Trying to finalize all the cuts on the cockpit before I start work on the wings.
Here is the removable cockpit. It should give a lot of access in the fuse to mount and maintain any parts that will be installed. Disregard the small piece of balsa under the cockpit base. It is just temporarily holding the upper 3/16 stringer in place till I decide on the final position.
Dave
Here is a pic of the cockpit base that will be glued to the stringer and tops of the fuse formers.
Here is the prototype cockpit sitting on that base. It will have bamboo dowels and a rare earth magnet to hold it in place.
Old May 09, 2013, 12:39 PM
Dpetsel's Avatar
Joined Jun 2012
I've been working on the wing mount and canopy. I got the canopy worked out and the wing mount. The cad cuts on the wing mount came out very precise. I used cf rods with brass inserts and will use small screw applied tabs to hold it in place. I am using an OS 3825 for the power which should be around 400 watts. The plane OAW so far is 30 oz. with motor and battery in place. Here are some pics of the progress.
Close up of the canopy
Canopy fuse opening
Motor test fit
Sliding wings on to test fit
A view of the wing pushed into place
Profile
Old May 09, 2013, 01:17 PM
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Subscribed!
Brian
cpdude is offline Find More Posts by cpdude
Old May 09, 2013, 01:22 PM
ulpilotrmh
ulpilotrmh's Avatar
USA, FL, Tavares
Joined Sep 2010
Subscribed. My first ride in any plane was in one of these in 1947 or 48.
Russ
ulpilotrmh is offline Find More Posts by ulpilotrmh
Old May 10, 2013, 02:14 AM
Editor - Flying Models
United States, CT
Joined Aug 2003
Looking great! Can't wait to see it come together.
Thayer is offline Find More Posts by Thayer
Old May 10, 2013, 11:42 AM
United States, MD, Frostburg
Joined Aug 2008
Very nice! It looks like it is coming together like a puzzle rather than a kit! That laser cutting is very nice.
4075aaron is offline Find More Posts by 4075aaron
Old May 10, 2013, 02:43 PM
Dpetsel's Avatar
Joined Jun 2012
It is a lot like a puzzle.
I like to change the model as I go. I have certain solutions to problems in my initial cad drawings and laser cuts. I build my original parts, decide if they are the right solutions, then I modify them to actual build problems. I then modify my master cad file to reflect those changes. I also try to do justice to the original scale design. Since I design most models to be electric powered I have to adjust the designs to make for maintenance in the event of electric component failure.
Old May 11, 2013, 02:15 AM
USA, CA,
Joined May 2001
Subscribed!
Excellent designing!
Joe Pierson is offline Find More Posts by Joe Pierson
Discussion republic seebee benjyre Balsa Builders 18 May 16, 2013 03:17 PM
Idea the United World Republic... UWR Kenny Sharp Life, The Universe, and Politics 161 Apr 20, 2013 08:23 AM
Discussion Governments and Republic's listed as Corporations? caymin last Life, The Universe, and Politics 0 Feb 05, 2013 01:40 PM
Build Log Republic XP-72 Super Thunderbolt - Design & Build roscoedude Scale Kit/Scratch Built 125 Jul 11, 2011 10:23 AM
Discussion Build Off: Republic RC-3 Seabee DBlum Scale Kit/Scratch Built 139 Oct 08, 2008 01:30 AM
