Old Aug 06, 2013, 04:19 AM
UK
Joined Nov 2002
Originally Posted by bjnginge View Post
Look mate I know how deltas work , I have three of them. If you took the time to look at the photo you would see inboard flaps and outboard elevons.
I assume when flaps are deployed that the elevons are used in a crow more like air brakes.
Just assuming, they could be used as separate elevator/aileron controls unless they are big trim tabs
Those are not inboard flaps, just split controls. Many full size do that, and mix so that if the pilot applies both elevator and aileron the bias shifts to moving the inboard ones as elevator and the outboard ones ailerons - the Avro Vulcan for example does that.
You can certainly move one pair down and one pair up but you don't get flap effect because the ones going up to compensate for the ones going down reduce the lift as much as the ones going down increase it, all you get is drag, so it doesn't allow the plane to land any slower because there is no additional lift.
There are ways for tailless aircraft to have lift increasing flaps and but they do not apply to standard deltas like the Mirage. One way is to have a controllable foreplane which can act to produce an upwards force to compensate for the nose down force created by lowering the trailing edge. Another is to have a highly swept trailing edge so that the inboard surfaces acting as flaps are close to the CG and have little pitch leverage whereas the outboard surfaces which are much further behind the CG can deflect just a little to compensate for the pitch change and thus not reduce the lift by as much as the inboard surfaces are increasing it.
HarryC is offline Find More Posts by HarryC
Old Aug 06, 2013, 09:39 AM
Joined Jul 2008
Fair enough. Has anyone built and flown this model? I have only seen one video, any feedback would be good.
bjnginge is offline Find More Posts by bjnginge
For Sale Mirage 2000 RTF 3DTRYER Aircraft - Electric - Jets (FS/W) 1 Mar 15, 2013 11:51 AM
Build Log profile MIRAGE 2000 D parkjet EPP 15mm pajlotmato Pusher Prop Jet Models 13 Feb 23, 2013 12:22 PM
Discussion my new flight S/W mirage 2000 lung0505 CAD/CAM 1 Feb 17, 2013 08:26 PM
Discussion TOPGUN's new Turbine Mirage 2000! Extreme_RC Extreme RC AUSTRALIA 0 Jan 30, 2013 05:58 PM
