Old Feb 16, 2013, 01:43 PM
Joined Jan 2013
Old monokote question
Howdy, all...
I'm in the process of bringing a Great Planes PT-40 back to life that I built but never flew about 20 years ago. Folks on the forums here have been very helpful getting the OS Max FP-40 up and running, the Futaba radio, receiver, and servos are all working, and are roughly trimmed correctly per the PT-40 manual.
Next question... I have two pretty substantial holes in the wing due to some cats we used to have (that have gone to that great kitty litter box in the sky, thankfully.. of old age, don't worry... ). After reading the forums, I've got a pretty good idea of how to go about patching them. Over the 20 years of just sitting there, the Monokote has developed some bubbles and wrinkles. How critical to good flight is a completely mirror-like surface? Should I poke a bunch of pinholes in it and re-iron it down? I remember when I was building it it seemed like every time I'd tack a bubble down, another one would appear next to it... I got kind of frustrated. When I finished it back in '94, it came out looking pretty good finally, but it's not as good now. Thoughts? Would it better to recover the whole plane after 20 years? I hope that's not necessary, but I've got more patience now than I used to and I'd probably do a better job.
Thanks..
Barry
musechaserpilot is offline Find More Posts by musechaserpilot
Old Feb 16, 2013, 02:07 PM
Arceenut's Avatar
Canada, BC, Langley
Joined Nov 2007
If ironing out a bubble causes more bubbles, the iron is too hot. I prick a hole at one edge of the bubble, then use a coolish iron, just enough to activate the glue and iron toward the pinhole.
Arceenut is offline Find More Posts by Arceenut
Old Feb 16, 2013, 07:42 PM
Fla.
Joined Apr 2005
If you patch any holes : cut your patch just a shade larger then the hole, then round all the corners before sealing. Sealing also brings up a point : after you have applied the patch seal all the edges real good . The round edges assist in keeping fuel out especially if sealed real good.
You might get by using your heat gun to make the plane look better. Just take your time and keep the gun moving, don't keep it in one spot long. Good Luck ENJOY !!! RED
redh is offline Find More Posts by redh
Old Feb 16, 2013, 08:03 PM
Denver, CO
Joined Dec 2005
If the covering was overheated it will likely never be really smooth. I would do just the patching needed to fly it. After a few flights the covering will take a new seat. So working to get the wrinkles out before a few flights might be a waste of time. If you really like it, a recovering might be in order. Some wrinkles will probably not be noticable in flight, unless they allow the wing to twist.
Best to measure the temperature of the iron. I use an infared thermometer. Most coverings packages have a recomended temperature on them. If unknown, and you have some scrap pieces, how it reacts to the iron, can give a good idea of the temperature to use.
Roto Rob is online now Find More Posts by Roto Rob
Old Feb 17, 2013, 08:53 AM
Joined Jan 2013
Thanks for all the tips, everyone. I'll patch it, then go after a couple of the larger bubbles on the fuselage with lower heat... it sounds like the problem might have been me being a little too enthusiastic with the heat setting the first time. The wing is pretty good except for the two holes, although this trainer is supposed to have 1/2" - 3/4" worth of wing twist or wash and I recall having trouble achieving that. The twist is supposed to help with stability and self recovery. Is it essential? I don't have a heat gun, and tried to do it with my wife's hair dryer. I also tried just rapidly moving the hot iron back and forth over the surface of the wing will twisting the wing. That was back when I first built the plane in '94. I guess I should remeasure, see if any twist still exists, and try again once it's patched, eh?
Thank you all again,
Barry
Old Feb 17, 2013, 12:42 PM
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
You are asking if the washout is necessary on a PT-40 trainer to fly? Not really. If the plans called for it I'd try and replicate what was supposed to have been there if possible, but i wouldnt sweat it if you cant get there. Its difficult ( not impossible) once the wing is built to get 1/2-3/4" of washout to stay into the wing by twisting & shrinking the covering. I'd finish repairing your holes & go fly. On future builds try shimming the trailing edge before you glue all your wing ribs in place & you'll have a better chance of keeping your washout in the wing.........Gene
gene6029 is online now Find More Posts by gene6029
Old Feb 18, 2013, 02:24 PM
Joined Jan 2013
Thanks for the tip re/ washout, Gene. I'll keep the shimming trick in mind for the next one! I measured it, and the washout is pretty much completely gone.
The good news is that I just finished patching the holes and ironing down most of the bigger bubbles and blisters. In body-shop lingo, it's about a 10-foot paint job.. <grin>... which I guess for this scale is not too good, but I'm happy with it.
Engine's running, holes are patched, electronics are good to go.. now I just need the snow gone so I can start taxiing a little bit..
Thanks for all the help!
Barry
Question Applying monokote details over monokote jsf135pal1 Painting and Finishing Tips 7 Jan 24, 2013 05:12 AM
Discussion old Kyosho boat question miltac Dock Talk 1 Jan 13, 2013 07:15 PM
Sold 2 old monokote irons and one old soldering gun BrianSmith Aircraft - General - Miscellaneous (FS/W) 2 Jan 27, 2011 08:54 AM
Discussion Question regarding old monokote... TGK Sailplane Talk 12 Jul 08, 2009 03:17 AM
Old CA? Old Monokote? -- Old still works sa-woody The Builders Workshop 4 Jan 24, 2005 12:20 PM
