Old Oct 10, 2011, 11:53 AM
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
1.3 whip antenna
Hey Guys,
I have the Turbine on the Rx, will it work with the stock whip on vtx?
Thanks!
It's hard to mount the viverant on the vtx
WBFlyer is offline Find More Posts by WBFlyer
Old Oct 10, 2011, 12:00 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Yes, but you'd be doing a huge disservice to not have CP on the transmitter side. You will notice your video is significantly worse.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Oct 10, 2011, 01:01 PM
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
Any good sugestions to mounting the 5 inch long cabled antenna? It was really stiff cable, then it would act just like a whip but...
Old Oct 10, 2011, 01:02 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I've flown with whip or V on the Tx and CP antennas on the Rx (SPW and Helical) and
it's just fine.
ian
Daemon is online now Find More Posts by Daemon
Old Oct 10, 2011, 01:43 PM
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
thanks Ian
Old Oct 10, 2011, 02:08 PM
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
Does anyone make a better whip? Lcom is very limited on products in this range
Old Oct 10, 2011, 02:31 PM
T#0
PilotKeeg's Avatar
Steamboat Springs, CO
Joined Aug 2010
you actually lose 3dbi in gain if you mix linear and cp... Use either all linear or all cp (same direction)
PilotKeeg is offline Find More Posts by PilotKeeg
Old Oct 10, 2011, 03:07 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The polarization loss isn't the problem. It's the combination of different design strategies. You wouldn't go putting a truck tires on your sports car would you? Will it work? Sure.
There is an easy solution: Shorten or stiffen the cable. Use fuel line to stiffen it.
-Alex
Old Oct 10, 2011, 03:11 PM
Why is the Rum gone?
sim_io's Avatar
USA, GA, Savannah
Joined Mar 2008
My friend had his helical circularized patch antenna on to watch my flight and sawdegradation at 3 miles out while my video was perfectly fine (dipole and patch antenna)
sim_io is offline Find More Posts by sim_io
Old Oct 10, 2011, 05:02 PM
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
So, how do you stiffen or shorten the cable? These are from True RC
Old Oct 10, 2011, 05:32 PM
Kmart's Avatar
United States, CO, Boulder
Joined Sep 2008
You can't shorten it unless you have a crimper.
Kmart is offline Find More Posts by Kmart
Old Oct 10, 2011, 06:12 PM
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
oh, well I don't so I guess I will try to use something to make it stiffer.. that's what she said.
Old Oct 11, 2011, 09:33 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^lol!
Discussion Whip antenna skippyc5 Fuel Jet Talk 4 Oct 09, 2011 08:30 PM
New Product BluBeam Whip antenna set IBCrazy FPV Talk 19 Sep 19, 2011 11:41 AM
Sold Hitec Electron 6 with Deans whip antenna Vintauri Aircraft - General - Radio Equipment (FS/W) 0 Jun 29, 2011 07:38 PM
