Old May 22, 2011, 09:29 PM
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Build Log
My First Build - UMX-Inspired Yak-55M
It's time for my first build: a UMX-inspired Yak-55M. The plane (with wood parts for control rods and carbon bracing) was furnished by forum member cpdude (thank you!).
Here are some pics of the parts as they arrived:
DSCF7877 by bryanewyatt, on Flickr
DSCF7881 by bryanewyatt, on Flickr
DSCF7878 by bryanewyatt, on Flickr
(I poked out some of the holes here)
DSCF7880 by bryanewyatt, on Flickr
I'm going to have LOTS of questions, as I've never assembled a plane from scratch before.
Wish me luck!
BryanEW710 is offline Find More Posts by BryanEW710
Old May 22, 2011, 10:52 PM
BryanEW710's Avatar
Joined Sep 2010
More pics from the build-up tonight...
I did the beveling with sandpaper. What do you guys think?
Build-up 005 by bryanewyatt, on Flickr
Build-up 004 by bryanewyatt, on Flickr
Here's the horizontal fuse mocked with the upper fuse. No CA used at this point:
Build-up 002 by bryanewyatt, on Flickr
All fuse components fully assembled:
Build-up 006 by bryanewyatt, on Flickr
Build-up 008 by bryanewyatt, on Flickr
Old May 23, 2011, 12:44 AM
BryanEW710's Avatar
Joined Sep 2010
Last pics for tonight.
Got the control surfaces installed:
Build-up 010 by bryanewyatt, on Flickr
Mocked it up one more time:
Build-up 011 by bryanewyatt, on Flickr
Took a shot of the 4-Site that will be giving up its servos and motor (and perhaps its carbon rods):
Build-up 009 by bryanewyatt, on Flickr
I then decided to tackle covering the horizontal surfaces. I stretched out a sheet of the covering material, then dusted 3M Super 77 on the upper surface and then laid it across the sheet and flattened it. Once it dried for a few minutes, I cut the plane out and made slits where the control surfaces were supposed to move.
I must have removed it a little more quickly than I should have and noticed that the left aileron's covering was loose. Stupidly, I sprayed the Super77 up close. It frothed on the foam...and began dissolving it!
Build-up 013 by bryanewyatt, on Flickr
Build-up 014 by bryanewyatt, on Flickr
To try to fix this, I cut a triangle of 3mm depron in half (making it 1.5mm or so thick and CA'ed it over the low area):
Build-up 017 by bryanewyatt, on Flickr
That's all for tonight!
Old May 23, 2011, 07:42 AM
BryanEW710's Avatar
Joined Sep 2010
This morning, I went back and beveled the ailerons to get more travel.
First question today: When I go to put the fuse together, do I cover the two sections separately and then attach them to the horizontal fuse?
Second question: Do I attach and cover the rudder before or after I attach the fuse?
Old May 23, 2011, 08:15 PM
United States, SC, Spartanburg
Joined Feb 2011
hi there, i love this!! i have the guts out of the micro su-29. i sat down with some 3 veiw drawings of the yak 55m and tried to resize them down to this size but it just didn't come out right. is there anyway i could get the drawings of what u have done here?? or can u help me out on that?? i know the su-29 had only 1 servo for the ailron and the 4-site had two but i'm sure using all the hardware i could get one to work. i'm very interested in this!!! i am a yak 55m lover!!! i love the way it flys!!!
thanks
mikey
madmikeyreturns is offline Find More Posts by madmikeyreturns
Old May 23, 2011, 08:56 PM
BryanEW710's Avatar
Joined Sep 2010
Check out the UMX Yak thread. There are several folks who have plans available. A couple of them will even laser cut you a plane out of foam like mine for a very nominal fee.
Old May 24, 2011, 12:48 AM
BryanEW710's Avatar
Joined Sep 2010
More updates!
Vertical surfaces tacked and curing on covering:
Build-up 018 by bryanewyatt, on Flickr
Lower fuse covered:
Build-up 019 by bryanewyatt, on Flickr
Covered upper fuse attached with thin CA:
Build-up 020 by bryanewyatt, on Flickr
First pic with lower fuse attached:
Build-up 021 by bryanewyatt, on Flickr
Unlike the horizontal control surfaces, which were covered and hinged in one step, the rudder was covered separately. Therefore, I used hinge tape (Blenderm) only:
Build-up 024 by bryanewyatt, on Flickr
Unfortunately, I didn't do as good a job with the horizontal surfaces as I did with the vertical ones
Build-up 027 by bryanewyatt, on Flickr
Close-up of the other side of the rudder:
Build-up 029 by bryanewyatt, on Flickr
The hole where the AR6400 will be sitting is in center of this pic. Not sure where I'm going to put the aileron servos, though...
Build-up 031 by bryanewyatt, on Flickr
Fuselage bracing:
Build-up 033 by bryanewyatt, on Flickr
Further away (and yes, I'm sitting between my furnace and the washer/dryer):
Build-up 032 by bryanewyatt, on Flickr
Installed the fences for wing bracing:
Build-up 035 by bryanewyatt, on Flickr
All ready for bracing, servos, and powertrain
Build-up 037 by bryanewyatt, on Flickr
Old May 25, 2011, 10:27 PM
BryanEW710's Avatar
Joined Sep 2010
Did a little bit of work today...
This was a mostly-intact 4-Site...until today!
Build-up 041 by bryanewyatt, on Flickr
Before that, I cut the electronics out of the plane...
Build-up 043 by bryanewyatt, on Flickr
...and salvaged as many of the CF rods from it as I could (sadly, the stack of 4 thin rods in the middle is the remains of the two rods cross-bracing the wing; the complete set is on the right)
Build-up 044 by bryanewyatt, on Flickr
Test-fitting the receiver:
Build-up 045 by bryanewyatt, on Flickr
Aileron servos and the first braces fitted (the right aileron pushrod actually goes at a slight angle to the control horn because the aileron servos are identical and not mirrored):
Build-up 047 by bryanewyatt, on Flickr
Also fitted a couple braces at the tail. I hope I'm not adding too much bracing...I'm just using what I have available!
Build-up 049 by bryanewyatt, on Flickr
Couldn't resist the urge to add another brace. The last one will likely be the other pair going to the main wing.
Build-up 050 by bryanewyatt, on Flickr
Old May 25, 2011, 11:26 PM
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Looking good!
cpdude is offline Find More Posts by cpdude
Old May 25, 2011, 11:34 PM
BryanEW710's Avatar
Joined Sep 2010
Wow...thank you! That means a lot!
I was meaning to ask because I've never really worked with something this small, but what kind of throws should I expect? Should I also dial the expo up quite a bit?
Old May 25, 2011, 11:45 PM
Joined Jan 2004
I may not be a good role model here! j/k!!
I usually go for the largest throws I can get mechanically then dial in a bunch of expo (40-50%). I'm also not a big fan of dual rates.
Old May 25, 2011, 11:51 PM
BryanEW710's Avatar
Joined Sep 2010
Interesting...I hadn't thought about not having dual rates, but I did think to bevel both sides of the control surfaces when I noticed that I didn't have great throws.
I'm a little worried about the right aileron, what with the pushrod running at a little angle. Does it look OK? I'm kind of impressed that I managed to eyeball that fitting!
Old May 25, 2011, 11:54 PM
Joined Jan 2004
The right aileron will probably be okay. You definitely should have moved the horn inboard a bit.
Old May 26, 2011, 12:12 AM
BryanEW710's Avatar
Joined Sep 2010
Yeah...I had made the mistake of mounting the horns symmetrically before I realize that the servos are identical
Rookie build mistake, eh?
I'm going to try coloring with a Sharpie before I mount the receiver. I also need to lengthen the rods for the rudder and elevator. I think for this one, I'm going to leave the landing gear off. I've already added too much weight!
Old May 26, 2011, 10:41 PM
BryanEW710's Avatar
Joined Sep 2010
Paintjob!
Did the last thing I wanted to get out of the way before adding the last of the bracing and then the receiver and powertrain: painting
All work done with a single blue Sharpie:
Build-up 052 by bryanewyatt, on Flickr
Build-up 051 by bryanewyatt, on Flickr
Well, what do you think?
Discussion UMX inspired Yak AJWoods Scratchbuilt Indoor and Micro Models 362 Nov 08, 2014 12:42 PM
Discussion A What If Build...inspired by Burnelli rc capo The Builders Workshop 15 Nov 30, 2013 01:43 PM
Sold UMX inspired YAK kit w/ electronics - $70 shipped obo Trapviper Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Apr 06, 2011 07:44 AM
Discussion New DW Foamies Yak 55M and SP Build Thread Joethefloorman 3D Foamies 85 Feb 06, 2011 02:29 AM
Discussion Yak 55m Build Log Nooflyer Indoor Pattern/F3P 5 May 20, 2008 03:38 PM
