Old Oct 18, 2013, 12:55 PM
tchalfant's Avatar
United States, NV, Las Vegas
Joined Aug 2011
Great information. Who do you recommend to get the magnetic switches from?
tchalfant is offline Find More Posts by tchalfant
Old Oct 18, 2013, 03:54 PM
Submarines, etc.
tsenecal's Avatar
Arvada, Colorado
Joined May 2005
engel:
http://www.engel-modellbau.eu/catalo...34jeu8gh1b8lu6
tsenecal is online now Find More Posts by tsenecal
Old Oct 18, 2013, 05:06 PM
Joined Mar 2006
I got my switches from engel as well.
stevesrc26 is offline Find More Posts by stevesrc26
Old Oct 18, 2013, 06:38 PM
tchalfant's Avatar
Joined Aug 2011
Thank you Tim and Steve!
Old Oct 20, 2013, 12:31 PM
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Hi,
A bit late but I got my switches from engel as well.
Please use a good strong magnet to be able to penetrate the Hull, engel sells them also
Regards,
Jan,
Horseman is offline Find More Posts by Horseman
Old Feb 23, 2014, 06:09 PM
ir3
Joined Dec 2007
I have a question. I am not 100% happy the location of the RX in the Tech Rack. It is at the forward most end of the tech rack and the space is quite limited. It is also difficult getting all 8 leads plugged into the end of the RX.
I found a better spot. One of the spacers for the for ballast tank mounting has a very nicely sized opening. It is where the spacer that has the VIIC symbol carved in it. The only problem that I see is that the RX will be just above the Ballast Tank motor. Engel claims that the motors on the ballast tanks are suppressed.
Should I worry about interference from the ballast tank motor? The new RX location quite handy and will significantly shorten a lot of the wiring. I have no problem making/shortening new leads, I just want to make sure that I am not creating a problem for myself.
Any comments either way would be greatly appreciated.
Iran
ir3 is offline Find More Posts by ir3
Old Feb 23, 2014, 06:13 PM
ir3
Joined Dec 2007
Sorry Jan, I was in your thread when I thought about the post. I hope you don't mind it being here also. I know that you have a good following on this thread. If you wish to remove it, no problem.
Best Regards,
Iran
Old Feb 24, 2014, 04:23 AM
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Hi Iran,
Please leave it here because you have a strong point.
The receiver location Engel want us to use is indeed very limited in space.
Your suggestion sound ok but I really do not know if the electrical motors will cause problems, they are indeed suppressed but I dont know how it will work.
Again a trial and error case with this Engel Kit.
Jan,
Cool 10 Foot Indoor C-47 Now with build pictures added R&RRC Foamies (Scratchbuilt) 132 Jul 18, 2014 03:24 PM
Build Log D-18/C-45, Build-up (ACME A.C. kit) Fly_Baby1A Scale Kit/Scratch Built 43 Jun 23, 2010 07:54 PM
Discussion C.N.C Machines are not necessary to build R/C airplanes! Mode One The Builders Workshop 38 Apr 20, 2010 01:35 PM
Question I want to build an Aviat Husky A1-C bsbauman Scale Kit/Scratch Built 26 Mar 19, 2010 08:28 PM
Engel Typhoon / Gato / U177 Build and Tips Wheelerdealer Submarines 40 Aug 07, 2007 11:27 AM
